devices = {
'81' -- Replace with the actual IDX of the switch
logging = {
level = domoticz.LOG_DEBUG, -- Can be changed to domoticz.LOG_INFO to reduce logging volume
local sensorName = '200' -- Replace with the actual IDX of the water sensor
local areaInSquareMeters = 1 -- Replace with actual area in square meters
if device.state == 'On' then
local amountOfWater = 0.52615 * areaInSquareMeters -- Calculates the amount of water
domoticz.devices(sensorName).updateCustomSensor(amountOfWater) -- Updates the custom water sensor
domoticz.log('Amount of water added: ' .. amountOfWater .. ' L', domoticz.LOG_DEBUG)
can somebody to corect the script ?
thx
script to check, it's not working
- Domoticz version: 2023.2
Re: script to check, it's not working
check this example
look where you place the braces
return
on =
devices = { 'Room switch'}
execute = function(domoticz, roomSwitch)
if (roomSwitch.active and domoticz.devices('Living room').temperature > 18) then
domoticz.devices('Another switch').switchOn()
domoticz.notify('This rocks!',
'Turns out that it is getting warm here',
domoticz.PRIORITY_LOW)
Bugs bug me.
- Domoticz version: 2024.7
I linked you to this script viewtopic.php?p=255592#p255592
Why did you not use that?
And if something is not working please indicate what is not working. But better use the script I linked to.
Make a dummy rain device (in the script named 'regenmeter').
I created the virtual sensor with the name regenmeter. I replaced the tippingbucketrain name with Terrace in the script, this being the element that transmits the information.
still no response from the dummy
return
on =
devices =
"tippingbucketrain",
logging =
level = domoticz.LOG_DEBUG, -- INFO, ERROR or DEBUG
marker = "ESP test",
execute = function(dz, item)
local rainDevice = dz.devices("Regenmeter") -- Your (virtual) rain device
local rainSwitch = dz.devices("Terasa") -- Your (triggered by bucket full) switch
local rainmm = 2 -- find out what 1 bucket full means in terms of mm
local rainTotal = 0
local timeSlice = math.min( (rainDevice.lastUpdate.secondsAgo / 3600), 10) -- at least 1 bucket in 10 hours
local rainAmountHour = dz.utils.round((rainmm / timeSlice),1)
if item.active then
rainTotal = dz.utils.round((rainmm + rainDevice.rain),1)
rainDevice.updateRain(rainAmountHour, rainTotal)
dz.log("One bucket full ==>> updating raindevice. rainrate: " .. rainAmountHour .. " mm/hr, " .. rainTotal .." mm in total today ", dz.LOG_DEBUG )
rainSwitch.switchOff().silent()
return
on =
devices =
logging =
local rainTotal = 0
if item.active then
As indicated please put code into brackets.
You did not replace tippingbicketrain to Terasa everywhere in the script. So the script will not be triggered when Terasa is switched.
