Graph overlays icons
Posted: Wednesday 06 September 2023 22:44
by janumix
Since abt. 2 beta versions back, custom graph overlays icons as follows:
- Screenshot_20230808_232547.png (67.58 KiB) Viewed 6480 times
Can't find any change in that matter in Release Notes.
The only workaround in to increase height param but then it does not scale to different resolutions as previously it was.
Re: Graph overlays icons
Posted: Thursday 07 September 2023 8:16
by Lokonli
I included some minor styling changes in a June update. Maybe it has some unexpected side effects.
Can you post the block definition for your graph block?
Do you make use of custom.js? If yes, can you post that as well?
How should it look like? The three domoticz device blocks should be shifted down? Can you post a 'before' picture?
Posted: Thursday 07 September 2023 13:54
by janumix
Sure.
Block definition:
blocks['Energia_3435'] = {
title: 'Energia',
devices: [138,232,135],
graphTypes: ['v'],
//ylabels: ['1f','3f','FV'],
graph: 'line',
height: 190,
buttonsSize: 10,
legend: false,
axisRight: true,
datasetColors: ['red','yellow','green']
custom.js:
function getExtendedBlockTypes(blocktypes){
//blocktypes.Type['Lighting 2'] = { icon: 'fa fa-lightbulb-o', title: '<Name>', value: 'ds' }
return blocktypes;
function getStatus_57(block, afterupdate){ // oświetlenie garażu
var idx = block.idx;
var device = block.device;
if(parseFloat(device['Data'])>0){
$('div.block_57').addClass('warning_light');
else {
$('div.block_57').removeClass('warning_light');
function getStatus_18(block, afterupdate){ // oświetlenie piwnicy
$('div.block_18').addClass('warning_light');
else {
$('div.block_18').removeClass('warning_light');
function getStatus_137(block, afterupdate){ // oświetlenie strychu - poddasza
$('div.block_137').addClass('warning_light');
else {
$('div.block_137').removeClass('warning_light');
function getStatus_40(block, afterupdate){
if(parseFloat(device['Data'])<210){
$('div.block_40').addClass('warning_light');
else {
$('div.block_40').removeClass('warning_light');
function getStatus_45(block, afterupdate){
if(parseFloat(device['Data'])<25){
$('div.block_45').addClass('warning_light');
else {
$('div.block_45').removeClass('warning_light');
function getStatus_80(block, afterupdate){
if(device['Data']!="Closed"){
$('div.block_80').addClass('warning_light');
else {
$('div.block_80').removeClass('warning_light');
function getStatus_7(block, afterupdate){
$('div.block_7').addClass('warning_light');
else {
$('div.block_7').removeClass('warning_light');
function getStatus_19(block, afterupdate){
$('div.block_19').addClass('warning_light');
else {
$('div.block_19').removeClass('warning_light');
function getStatus_28(block, afterupdate){
$('div.block_28').addClass('warning_light');
else {
$('div.block_28').removeClass('warning_light');
function getStatus_46(block, afterupdate){
if(device['Data']!="Off"){
$('div.block_46').addClass('warning_light');
else {
$('div.block_46').removeClass('warning_light');
function getStatus_83(block, afterupdate){
$('div.block_83').addClass('warning_light');
else {
$('div.block_83').removeClass('warning_light');
function getStatus_141(block, afterupdate){
$('div.block_141').addClass('warning_light');
else {
$('div.block_141').removeClass('warning_light');
function getStatus_100(block, afterupdate){
if(parseFloat(device['Data'])<1){
$('div.block_100').addClass('warning_light');
else {
$('div.block_100').removeClass('warning_light');
function getStatus_101(block, afterupdate){
$('div.block_101').addClass('warning_light');
else {
$('div.block_101').removeClass('warning_light');
function getStatus_245(block, afterupdate){
$('div.block_245').addClass('warning_light');
else {
$('div.block_245').removeClass('warning_light');
Posted: Thursday 07 September 2023 21:44
by Lokonli
Thanks.
I've made some changes to the height computation of a graph block.
Can you test latest dashticz beta?
Update Dashticz with 'git pull'
Small change: You probably have to increase the height value of your graph block. With the new version, the value of the height parameter sets the height of the complete block, including header with buttons.
Posted: Thursday 07 September 2023 22:49
by janumix
Now it's great !
Thanks a lot.
No need to adjust height.
