Brel & Dooya bi-directional motor supported
Posted: Monday 04 September 2023 15:17
by b_weijenberg
Domoticz Beta version 2023.2 (July 21 2023) supports Brel and Dooya (and other compatibles) bi-directional motors using the Blinds - Brel DDxxxx.
This needs the RFXusb-RFX433, RFX433XL-USB, RFX433XL-Wifi or RFX433XL-LAN version and at least firmware version 2024.
Big advantage of these DDxxxx motors is that they have the percentage open command.
Note: This is not supported by the RFXtrx433, RFXtrx433E and RFXtrx433XL. These types do not support FSK modulation which is necessary for the DDxxxx protocol.
Re: Brel & Dooya bi-directional motor supported
Posted: Thursday 14 December 2023 14:13
by Levimme
My Domoticz has Beta version (Build 15724) to which the RFX433XL-USB is connected. I want to use this to control screens with a Brel motor type BREL BR35-13. With RFXmngr I was able to pair and control the Brel motors with the RFX433XL-USB. However, this does not work with Domoticz. Am I doing something wrong?
Posted: Thursday 14 December 2023 14:20
by Levimme
The BREL motors are type: BLE35-13. Sorry.
Posted: Thursday 14 December 2023 14:33
by b_weijenberg
How is the device configured in Domoticz?
As BREL DDxxxx?
Using the same ID and unit code as in RFXmngr?
Posted: Thursday 14 December 2023 16:08
by Levimme
In RFXmngr paired with the DD**** protocol and in Domoticz Subtype DC106. Setmode RFXCOM Blind T1/T2/T3/T4
Posted: Thursday 14 December 2023 16:09
by b_weijenberg
You need the BREL DDxxxx device in Domoticz for the bi-directional Brel!
Posted: Thursday 14 December 2023 16:38
by Levimme
I don't have a setting in Domoticz for DD****.
Posted: Thursday 14 December 2023 16:46
by b_weijenberg
Add Manual Light/Switch Device
Hardware: RFX433
Switch Type: Blinds
Type: Brel DDxxxx
Posted: Thursday 14 December 2023 17:43
by Levimme
Thanks for your help, it works!!!
Posted: Thursday 04 January 2024 15:26
by ArnoutZ
I have a similar problem as above.
I have paired my Brel bidirectional blinds via RFXmngr, so I can sends commands from there, but if I want to add a manual switch to Domoticz, I see various types/brands of blinds, but I do not see the Brel DDxxx type.
BTW, I am running Domoticz 2023.2 (build 15457). Is that the reason?
Update: I upgraded to the new domoticz 2024.1 version and now I have the DDxxx type as an option, so problem solved.
