Create device JSON failed
michelscholte
Post by michelscholte »
I'v tried to create e device with JSON. Type is 244 (light/switch) and subtype is 62 (selector). I have the last release 2023.2.
/json.htm?type=command&param=createdevice&idx=HWIDX&name=TEST&sensormappedtype=244
"status" : "ERR"
Also the older command doesn't'work.
Hopefully someone can help me.
jvdz
Domoticz version: 4.107
Re: Create device JSON failed
Post by jvdz »
Have you checked the log as I assume it tells you that this format API format has changed!
https://www.domoticz.com/wiki/Domoticz_ ... d_newer.29
michelscholte
Thanks for your answer.
As you can see in my post I use the NEW command. It's not working with this new command.
jvdz
Post by jvdz »
Ah ... you're (of course) right.
Maybe a security issue as that change substantially too?
Shouldn't your url also include the subtype?
/json.htm?type=command&param=createdevice&idx=HWIDX&name=TEST&sensormappedtype=244&devicesubtype=62
michelscholte
Unfortunately same issue.
http://192.168.1.114:8080/json.htm?type ... subtype=62
Creating of new hardware/sensors is already enabled,. So, also that cannot be the problem.
kiddigital
Post by kiddigital »
What HTTP response code do you get? 200 or something else?
Try running domoticz with some debug flags enabled by setting ‘-debuglevel normal,hardware,auth’ for example.
Just to be sure..
You have to change HWIDX to an enabled dummy hardware gateway idx number or other hardware gateway that is controlling the device.
