Why switchOn sends brightness:254 instead of state:on?
dariann
Domoticz version: 2023.2
Post by dariann »
Hi All,
I have a power supply driven by zigbee2mqtt which is activated by sending data to the "zigbee2mqtt/pwr_bookshelf1/set" topic. I am toggling its state by "switchOn" and "switchOff" like in this script:
		devices = {
			'btn_square1_action_on',
			'btn_square1_action_off'
	logging = {
		level = domoticz .LOG_INFO,
		marker = 'btsqonoff',
	execute = function(dz, dev)
		dz. log('Device ' .. dev .name .. ' was changed with value: ' .. dev .state, dz .LOG_INFO)
		if (dev .state == 'On') then
		    dz. devices('pwr_bookshelf1').switchOn()
		    dz. devices('pwr_bookshelf1').switchOff()
On "switchOff()" call I see {"state": "OFF"} in the topic payload, but on "switchOn" call see {"brightness": 254}. Does anyone know why? I expected {"state": "ON"}, but I don't know how to change it. With "brightness" set directly, my led light is turning on instantly, while with "state" it does smoothly.
I suppose that it may be somehow connected with device type, but I am not sure. Anyway, at Domoticz devices list, the "pwr_bookshelf1" device type is "Light/Switch" and subtype is "Switch".
dariann
Re: Why switchOn sends brightness:254 instead of state:on?
Post by dariann »
After some digging, I have noticed that on "Switches" dashboard I have a switch "pwr_bookshelf1" with description "Light/Switch, Switch, Dimmer", so I clicked "edit" and changed "Switch Type" from "Dimmer" to "On/Off". As a result, I started getting payload {"state": "ON"} as expected, but dimmer functionality was gone.
Does anyone know how to preserve expected payload with dimmer functionality?
Why do you want to know this? Do you want to interfere with the Domoticz/Zigbee2MQtt interface?
You can go the the MQTT AUtodiscover hardware source code to find the logic: https://github.com/domoticz/domoticz/bl ... scover.cpp
Also check the MQTT AD documentation for switch/light: https://www.home-assistant.io/integrati ... son-schema
dariann
Post by dariann »
Because of the behavior "pwr_bookshelf1" which is different depending on the payload. In case it is:
  • {"state": "ON"}, the LED light is turning on smoothly
  • {"brightness": 254"}, the LED light is turning on instantly
I would like to turn it on smoothly instead of instantly, thus my question. Is it feasible? Or, maybe there is an other way?
jvdz
Domoticz version: 4.107
Post by jvdz »
What is the discovery mqtt message content for this device as that is used to determine what to send for On?
dariann
Post by dariann »
Could you tell me which topic of zegbee2mqtt says that?
For instance, using MQTT Explorer I found this one:
* homeassistant/select/0x84fd27fffe47d363/power_on_behavior/config
	"availability": [
			"topic": "zigbee2mqtt/bridge/state",
			"value_template": "{{ value_json.state }}"
			"topic": "zigbee2mqtt/pwr_bookshelf1/availability",
	"availability_mode": "all",
	"brightness": true,
	"brightness_scale": 254,
	"command_topic": "zigbee2mqtt/pwr_bookshelf1/set",
	"device": {
		"identifiers": [
			"zigbee2mqtt_0x84fd27fffe47d363"
		"manufacturer": "IKEA",
		"model": "TRADFRI driver for wireless control (30 watt) (ICPSHC24-30EU-IL-1)",
		"name": "pwr_bookshelf1",
		"sw_version": "1.2.245"
	"effect": true,
	"effect_list": [
		"blink",
		"breathe",
		"okay",
		"channel_change",
		"finish_effect",
		"stop_effect"
	"schema": "json",
	"state_topic": "zigbee2mqtt/pwr_bookshelf1",
	"unique_id": "0x84fd27fffe47d363_light_zigbee2mqtt"
and this one:
* homeassistant/light/0x84fd27fffe47d363/light/config
	"availability": [
	"brightness": true,
	"device": {
		"identifiers": [
	"effect": true,
	"effect_list": [
		"blink",
		"breathe",
		"okay",
		"channel_change",
		"finish_effect",
		"stop_effect"
	"schema": "json",
or maybe this one (I just left the data of "pwr_bookshelf1" and cut others):
* zigbee2mqtt/bridge/devices
		"date_code": "20170529",
		"definition": {
			"description": "TRADFRI driver for wireless control (30 watt)",
			"exposes": [
					"features": [
							"access": 7,
							"description": "On/off state of this light",
							"name": "state",
							"property": "state",
							"type": "binary",
							"value_off": "OFF",
							"value_on": "ON",
							"value_toggle": "TOGGLE"
							"access": 7,
							"description": "Brightness of this light",
							"name": "brightness",
							"property": "brightness",
							"type": "numeric",
							"value_max": 254,
							"value_min": 0
					"type": "light"
					"access": 2,
					"description": "Triggers an effect on the light (e.g. make light blink for a few seconds)",
					"name": "effect",
					"property": "effect",
					"type": "enum",
					"values": [
						"blink",
						"breathe",
						"okay",
						"channel_change",
						"finish_effect",
						"stop_effect"
					"access": 7,
					"description": "Controls the behavior when the device is powered on after power loss",
					"name": "power_on_behavior",
					"property": "power_on_behavior",
					"type": "enum",
					"values": [
						"off",
						"on",
						"toggle",
						"previous"
					"access": 1,
					"description": "Link quality (signal strength)",
					"name": "linkquality",
					"property": "linkquality",
					"type": "numeric",
					"unit": "lqi",
					"value_max": 255,
					"value_min": 0
			"model": "ICPSHC24-30EU-IL-1",
			"options": [
					"access": 2,
					"description": "Controls the transition time (in seconds) of on/off, brightness, color temperature (if applicable) and color (if applicable) changes. Defaults to `0` (no transition).",
					"name": "transition",
					"property": "transition",
					"type": "numeric",
					"value_min": 0
					"access": 2,
					"description": "State actions will also be published as 'action' when true (default false).",
					"name": "state_action",
					"property": "state_action",
					"type": "binary",
					"value_off": false,
					"value_on": true
			"supports_ota": true,
			"vendor": "IKEA"
		"disabled": false,
		"endpoints": {
			"1": {
				"bindings": [],
				"clusters": {
					"input": [
						"genBasic",
						"genIdentify",
						"genGroups",
						"genScenes",
						"genOnOff",
						"genLevelCtrl",
						"haDiagnostic",
						"touchlink"
					"output": [
						"genScenes",
						"genOta",
						"genPollCtrl",
						"touchlink"
				"configured_reportings": [],
				"scenes": []
		"friendly_name": "pwr_bookshelf1",
		"ieee_address": "0x84fd27fffe47d363",
		"interview_completed": true,
		"interviewing": false,
		"manufacturer": "IKEA of Sweden",
		"model_id": "TRADFRI Driver 30W",
		"network_address": 58868,
		"power_source": "Mains (single phase)",
		"software_build_id": "1.2.245",
		"supported": true,
		"type": "Router"
dariann
Post by dariann »
I haven't found solution, so I used Node-RED for this and it works very well, so maybe this message thread should be placed in different topic? Maybe which is about Zigbee integration with Domoticz, but I am not sue.
Anyway, below is a screenshot of Node-RED nodes which I used. Unfortunately, my Ikea button states:
https://www.zigbee2mqtt.io/devices/E1743.html
are recognized in different topics by zigbee2mqtt, but not JSON payload. However, using change nodes I replaced payload with required by power driver:
https://www.zigbee2mqtt.io/devices/ICPS ... -IL-1.html
and it works as I wanted.
