Selector Switch problem above level 25 after upgrade
michelscholte
Post by michelscholte »
I have a problem with switching a selector switch above 25.
I use command:
http://192.168.1.114:8080/json.htm?type ... &level=260
I got a positive result back:
"status" : "OK",
"title" : "SwitchLight"
Then in the GUI it shows "Undefined" and shows the last level (30):
It's a newly created selector switch. Older created selector switches works fine.
I updated my Domoticz to the last Beta (build 15525) but problem still exist.
Anyone an idea. Thanks in forward.
Re: Selector Switch problem above level 25 after upgrade
It is a known issue for > 31 see https://github.com/domoticz/domoticz/issues/5324
michelscholte
Thank you for your reply.
Strange thing is that it works for selector switches created with the developer python plugin. I have one (40 levels) for my radio/receiver and I'm able to switch also the higher levels.
Perhaps put your findings in the GitHub issue. I am not a developper. No idea what could be wrong here.
