I have a switch with 4 buttons and every button has 3 functions. Can i config this switch as 1switch in autodiscover? Now it makes for every funktion (1 puls 2 pulses and hold) a different button in zigbee. With the old zigbee plugin it was seen as 1 switch with 12 functions.
switch is a Tuya 4-button Scene Switch
Howto learn a switch with 4 buttons as 1 switch
sunlight
Re: Howto learn a switch with 4 buttons as 1 switch
Its a Tuya 4 button switch TS004F. Still no luck. Hopefully someone can help with the right sollution.
- Domoticz version: 2026.3
I am not using MQTT Autodiscover but I dont think this gateway is able to merge separate switches in one selector switch like the plugin does.
You could think of using Zigbee4Domoticz python plugin (and get rid of Zigbee2MQTT) but this will be some work only for some small enhancement.
