Piface domoticz insisde Docker with Portenair
Posted: Sunday 27 August 2023 21:03
by nicoweb56
Sorry for my English, I m French
I use domoticz since 5 years. Since last update, I must use Zwaze JS UI with docker, partainer...
All is ok Zwave with mosquitto and all is ok with RFXCam by /dev/ttyUSB0 in the portainer script
But I can use ans integrate Piface 2 interface GPIO (SPI is enable)
- /dev/gpiomem:/dev/gpiomem ?
Have you got solutions ?
Thanks for all
Nicolas
Re: Piface domoticz insisde Docker with Portenair
Posted: Sunday 27 August 2023 21:18
That Zwave-JS-UI is in a docker does not mean that Domoticz has to be in a docker. You can install Domoticz like before and use the piface like before.
Perhaps someone else can tell how piface should configured with Domoticz in a docker. But if that is not happening then you can still use Domoticz in the normal way.
Posted: Sunday 27 August 2023 21:45
by nicoweb56
Before today, domoticz was installed in direct on os but since today domoticz doesn t work. I have all erase on sdd and install all programme..
the standard installation of domoticz is ok but the web server don t work. I uses it since several year and i don t uderstand. I install domoticz docker it s work
Sudo service domoticz status is ok but i can t connect on web serveur with the good port. No connection. Portainer is ok and zwaze js is ok
Posted: Sunday 27 August 2023 22:16
What error do you get in the log file of Domoticz when installed on OS? Check troubleshooting wiki how to set it to write to OS.
From the error you get you perhaps can search further why it fails now suddenly after update...
