error gathering device information no such file or directory
Posted: Sunday 27 August 2023 13:54
by rron
i have trouble installing zwavejsui with docker compose. I allways get the error "error gathering dev. information while adding custom device "/dev/serial/by-id/usb-0658_0200_if00"no such file or directory.
My device is zwave Aeotec gen 5 stick. Rpi 4 with 32 bits pi os lite Bullseye.
zwave-js-ui:
containerversion: "3.7"
services:
zwave-js-ui:
container_name: zwave-js-ui
image: zwavejs/zwave-js-ui:latest
restart: always
tty: true
stop_signal: SIGINT
environment:
- SESSION_SECRET=mysupersecretkey
- ZWAVEJS_EXTERNAL_CONFIG=/usr/src/app/store/.config-db
# Uncomment if you want log times and dates to match your timezone instead of UTC
# Available at https://en.wikipedia.org/wiki/List_of_tz_database_time_zones
#- TZ=America/New_York
networks:
- zwave
devices:
# Do not use /dev/ttyUSBX serial devices, as those mappings can change over time.
# Instead, use the /dev/serial/by-id/X serial device for your Z-Wave stick.
- '/dev/serial/by-id/usb-0658_0200-if00:/dev/zwave'
volumes:
- zwave-config:/usr/src/app/store
# Or by using local folder
# - ./store:/usr/src/app/store
ports:
- "8091:8091" # port for web interface
- "3000:3000" # port for Z-Wave JS websocket server
networks:
zwave:
volumes:
zwave-config:
Lsusb will give
ID 0658:0200 Sigma Designs, Inc. Aeotec Z-Stick Gen 5 (ZW090) -UZB
What am I doing wrong? I installed the systeem 2 times from scratch, every time the same error.
Re: error gathering device information no such file or dit
Posted: Sunday 27 August 2023 14:11
by Sjonnie2017
First thing that comes to mind is the " before /dev/serial blah blah. There is no closing " so probably won't work. Try without the "
Re: error gathering device information no such file or directory
Posted: Sunday 27 August 2023 14:23
by rron
Hi Sjonnie2017,
That was a typo. I changed that in the compose file. In the original compose I use is that OK.Still the same error.
Posted: Sunday 27 August 2023 15:46
by rron
Domoticz docker works perfect.
I have also tested de stick with a powered hub on the pi4 but that didn’t make any diference.
Posted: Monday 28 August 2023 20:59
by rron
Someone an tip how to solve this? I ‘m out of ideas.
Posted: Monday 28 August 2023 22:36
Also search the discussion topics of Zwave-JS-UI
https://github.com/zwave-js/zwave-js-ui/discussions
Edit: check this guide to get the correct port name by-id
https://github.com/zwave-js/zwave-js-ui ... sions/2483
Posted: Tuesday 29 August 2023 17:34
by rron
that shows no such file or directory
/bin/udevadm info --name=/dev/ttyACM0 | grep SERIAL
that shows
Posted: Tuesday 29 August 2023 19:28
Then you cannot use by-id due to some issue with your OS or perhaps outdated?
You can use /dev/ttyACM0 in your docker config as that is the port it is using. Only after a reboot the order can change.
In this post is described how someone else fixed this issue
viewtopic.php?t=40536
Posted: Tuesday 29 August 2023 20:48
by rron
sudo nano /usr/lib/udev/rules.d/60-serial.rules
# do not edit this file, it will be overwritten on update
ACTION=="remove", GOTO="serial_end"
SUBSYSTEM!="tty", GOTO="serial_end"
SUBSYSTEMS=="usb", IMPORT{builtin}="usb_id", IMPORT{builtin}="hwdb --subsystem=usb"
SUBSYSTEMS=="pci", ENV{ID_BUS}=="", ENV{ID_BUS}="pci", \
ENV{ID_VENDOR_ID}="$attr{vendor}", ENV{ID_MODEL_ID}="$attr{device}", \
IMPORT{builtin}="hwdb --subsystem=pci"
# /dev/serial/by-path/, /dev/serial/by-id/ for USB devices
KERNEL!="ttyUSB[0-9]*|ttyACM[0-9]*", GOTO="serial_end"
SUBSYSTEMS=="usb-serial", ENV{.ID_PORT}="$attr{port_number}"
IMPORT{builtin}="path_id"
ENV{ID_PATH}=="?*", ENV{.ID_PORT}=="", SYMLINK+="serial/by-path/$env{ID_PATH}"
ENV{ID_PATH_WITH_USB_REVISION}=="?*", ENV{.ID_PORT}=="", SYMLINK+="serial/by-path/$env{ID_PATH_WITH_USB_REVISION}"
ENV{ID_PATH}=="?*", ENV{.ID_PORT}=="?*", SYMLINK+="serial/by-path/$env{ID_PATH}-port$env{.ID_PORT}"
ENV{ID_PATH_WITH_USB_REVISION}=="?*", ENV{.ID_PORT}=="?*", SYMLINK+="serial/by-path/$env{ID_PATH_WITH_USB_REVISION}-port$env{.ID_PORT}"
ENV{ID_BUS}=="", GOTO="serial_end"
ENV{ID_SERIAL}=="", GOTO="serial_end"
ENV{ID_USB_INTERFACE_NUM}=="", GOTO="serial_end"
ENV{.ID_PORT}=="", SYMLINK+="serial/by-id/$env{ID_BUS}-$env{ID_SERIAL}-if$env{ID_USB_INTERFACE_NUM}"
ENV{.ID_PORT}=="?*", SYMLINK+="serial/by-id/$env{ID_BUS}-$env{ID_SERIAL}-if$env{ID_USB_INTERFACE_NUM}-port$env{.ID_PORT}"
LABEL="serial_end"
Still have the same problem. I use bullseye OS. What version will work without this problem? Should I use Buster OS?
Posted: Tuesday 29 August 2023 21:24
I have no idea, not using an RPI.
Posted: Wednesday 30 August 2023 7:42
by rron
Hi Walter,
thanks for the help. It's strange that I don't seen this problem mentioned by other people. I will try a install from scratch with Buster and see what's happening.
Posted: Friday 01 September 2023 10:07
by rron
With Buster still the same error. I ' m running out of ideas. Can someone give me a help with this please? Aeontec stick will work with openzwave, i have just tested that so it looks that is not the problem.
Posted: Saturday 02 September 2023 11:59
by rron
Tested the aeontec gen 5 stick on the rpi4 with domoticz installed with
sudo bash -c "$(curl -sSfL https://install.domoticz.com)"
and there no problem.
But with docker zwavejsui no access to aeontec gen 5 stick. I have also down a kernel update success.
Posted: Saturday 02 September 2023 16:24
As it is a Zwave-JS-UI issue you could also check the Zwave-JS-UI GitHub issues or forum. Perhaps ask it there.
Posted: Sunday 03 September 2023 10:25
by rron
waltervl wrote: Saturday 02 September 2023 16:24
Yes I could but then again I see that a lot of folks have implemented Zwave-JS-UI without the problems that I experienced so I figured out that I’m doing something wrong with every attempt and I cann’t stand that. The forum/wiki makes it looks easy.
