Installing Domotics on Allwinner D1
DanilinSA
Domoticz version: 2023.2
Post by DanilinSA »
There is a board based on the Allwiner D1 chip (Nezha C906 RISC-V). Sipeed Lichee RV Dock board.
The board is officially supported by the Ubuntu community.
Installed Ubuntu 23_04
I'm trying to install according to the instruction.
But there is no support package for this platform. domoticz_linux_riscv64 not found.
Compiling by hand is my only way?
Re: Installing Domotics on Allwinner D1
Yes, risc64 is not build. You have to do it yourself.
DanilinSA
Post by DanilinSA »
Collected.
It was very long. The "make" command took 38 hours to complete.
Everything starts normally, but after a couple of minutes the services stop. Attached are the start and stop logs. (Replaced dots with underscores.)
Start:
2023-08-21 19:22:10_110  [3f85c9d680] Status: Domoticz V2023_2 (build 15504) (c)2012-2023 GizMoCuz
2023-08-21 19:22:10_111  [3f85c9d680] Status: Build Hash: 9154599b1, Date: 2023-08-18 13:16:38
2023-08-21 19:22:10_111  [3f85c9d680] Status: Startup Path: /home/ubuntu/dev-domoticz/
2023-08-21 19:22:10_218  [3f85c9d680] Error: Default admin password has NOT been changed! Change it asap!
2023-08-21 19:22:10_802  [3f85c9d680] Status: PluginSystem: Started, Python version '3_11_4', 1 plugin definitions loaded_
2023-08-21 19:22:10_843  [3f85c9d680] Active notification Subsystems: fcm, http (2/13)
2023-08-21 19:22:10_845  [3f85c9d680] Debug: CWebServer::StartServer() : settings : 'server_settings[is_secure_=false, www_root='/home/ubuntu/dev-domoticz/www', listening_address='::', listening_port='8080', vhostname='', php_cgi_path='']'
2023-08-21 19:22:10_845  [3f85c9d680] Debug: CWebServer::StartServer() : IAM settings : 'iam_settings[is_enabled_=true, auth_url='/oauth2/v1/authorize', token_url='/oauth2/v1/token', discovery_url='/_well-known/openid-configuration', code_expire_seconds='60', token_expire_seconds='3600', refresh_expire_seconds='86400']'
2023-08-21 19:22:10_850  [3f85c9d680] Status: WebServer(HTTP) started on address: :: with port 8080
2023-08-21 19:22:10_858  [3f85c9d680] Debug: WebServer(HTTP) started with 233 Registered Commands
2023-08-21 19:22:10_858  [3f85c9d680] Debug: cWebEm Registration: 10 pages, 10 actions, 4 whitelist urls, 12 whitelist commands
2023-08-21 19:22:10_861  [3f85c9d680] Debug: CWebServer::StartServer() : settings : ssl_server_settings['server_settings[is_secure_=true, www_root='/home/ubuntu/dev-domoticz/www', listening_address='::', listening_port='443', vhostname='', php_cgi_path='']', ssl_method='tls', certificate_chain_file_path='_/server_cert_pem', ca_cert_file_path='_/server_cert_pem', cert_file_path=_/server_cert_pem', private_key_file_path='_/server_cert_pem', private_key_pass_phrase='', ssl_options='single_dh_use', tmp_dh_file_path='_/server_cert_pem', verify_peer=false, verify_fail_if_no_peer_cert=false, verify_file_path='']
2023-08-21 19:22:10_862  [3f85c9d680] Debug: CWebServer::StartServer() : IAM settings : 'iam_settings[is_enabled_=true, auth_url='/oauth2/v1/authorize', token_url='/oauth2/v1/token', discovery_url='/_well-known/openid-configuration', code_expire_seconds='60', token_expire_seconds='3600', refresh_expire_seconds='86400']'
2023-08-21 19:22:10_916  [3f85c9d680] Debug: [web:443] Enabled ciphers (TLSv1_2) ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384
2023-08-21 19:22:10_961  [3f85c9d680] Debug: [web:443] 'DH PARAMETERS' found in file _/server_cert_pem
2023-08-21 19:22:10_968  [3f85c9d680] Status: WebServer(SSL) startup failed on address :: with port: 443: bind: Permission denied, trying ::
2023-08-21 19:22:10_981  [3f85c9d680] Debug: [web:443] Enabled ciphers (TLSv1_2) ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384
2023-08-21 19:22:11_025  [3f85c9d680] Debug: [web:443] 'DH PARAMETERS' found in file _/server_cert_pem
2023-08-21 19:22:11_029  [3f85c9d680] Status: WebServer(SSL) startup failed on address :: with port: 443: bind: Permission denied, trying 0_0_0_0
2023-08-21 19:22:11_041  [3f85c9d680] Debug: [web:443] Enabled ciphers (TLSv1_2) ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384
2023-08-21 19:22:11_080  [3f85c9d680] Debug: [web:443] 'DH PARAMETERS' found in file _/server_cert_pem
2023-08-21 19:22:11_083  [3f85c9d680] Error: WebServer(SSL) startup failed on address 0_0_0_0 with port: 443: bind: Permission denied
2023-08-21 19:22:11_083  [3f85c9d680] Error: WebServer(SSL) check privileges for opening ports below 1024
2023-08-21 19:22:11_090  [3f85c9d680] Starting shared server on: :::6144
2023-08-21 19:22:11_093  [3f81ffaf20] Status: TCPServer: shared server started___
2023-08-21 19:22:11_097  [3f80ff8f20] Status: RxQueue: queue worker started___
2023-08-21 19:23:10_849  [3f837fdf20] Debug: [web:8080] cleaning sessions___
2023-08-21 19:23:10_850  [3f837fdf20] Debug: SessionStore : clean___
2023-08-21 19:23:20_074  [3f82ffcf20] Debug: [web:8080] Host:192_168_88_102 Uri:/app/events/Events_css
2023-08-21 19:23:20_074  [3f82ffcf20] Debug: [web:8080] Request Headers:
Host: 192_168_88_76:8080
Connection: keep-alive
User-Agent: Mozilla/5_0 (Windows NT 10_0; Win64; x64) AppleWebKit/537_36 (KHTML, like Gecko) Chrome/115_0_0_0 Safari/537_36 Edg/115_0_1901_203
Accept: text/css,*/*;q=0_1
Referer: http://192_168_88_76:8080/
Accept-Encoding: gzip, deflate
Accept-Language: ru,en;q=0_9,en-GB;q=0_8,en-US;q=0_7
If-None-Match: 2023_2 (build 15504)
If-Modified-Since: Sat, 19 Aug 2023 10:49:41 GMT
2023-08-21 19:23:20_075  [3f82ffcf20] Debug: [web:8080] isPage 0 isAction 0 isUpgrade 0 needsAuthentication 1 isAuthenticated 0 ()
2023-08-21 19:23:20_083  [3f82ffcf20] Debug: Web ACLF: 192_168_88_102 - - [21/Aug/2023:19:23:20_074 +0300] "GET /app/events/Events_css HTTP/1_1" 304 0 "http://192_168_88_76:8080/" "Mozilla/5_0 (Windows NT 10_0; Win64; x64) AppleWebKit/537_36 (KHTML, like Gecko) Chrome/115_0_0_0 Safari/537_36 Edg/115_0_1901_203"
2023-08-21 19:23:20_085  [3f82ffcf20] Debug: [web:8080] Host:192_168_88_102 Uri:/app/devices/Devices_css
2023-08-21 19:23:20_085  [3f82ffcf20] Debug: [web:8080] Request Headers:
2023-08-21 19:23:20_086  [3f82ffcf20] Debug: [web:8080] isPage 0 isAction 0 isUpgrade 0 needsAuthentication 1 isAuthenticated 0 ()
2023-08-21 19:23:20_086  [3f82ffcf20] Debug: Web ACLF: 192_168_88_102 - - [21/Aug/2023:19:23:20_085 +0300] "GET /app/devices/Devices_css HTTP/1_1" 304 0 "http://192_168_88_76:8080/" "Mozilla/5_0 (Windows NT 10_0; Win64; x64) AppleWebKit/537_36 (KHTML, like Gecko) Chrome/115_0_0_0 Safari/537_36 Edg/115_0_1901_203"
2023-08-21 19:23:20_089  [3f82ffcf20] Debug: [web:8080] Host:192_168_88_102 Uri:/js/domoticz_js
2023-08-21 19:23:20_089  [3f82ffcf20] Debug: [web:8080] Request Headers:
Accept: */*
If-Modified-Since: Sat, 19 Aug 2023 10:49:43 GMT
Stop:
2023-08-21 19:27:06_952  [3f82ffcf20] Debug: SessionStore : get___(705d6529d9c2583e91c4ebfdaee8b45d)
2023-08-21 19:27:06_954  [3f82ffcf20] Debug: [web:8080] CheckAuthToken(705d6529d9c2583e91c4ebfdaee8b45d_OTEzNzAxNTctZDBiYi00NTcyLWEyYzktYzM4MmU1Y2Q0ZGQ0_admin) : user authenticated
2023-08-21 19:27:06_954  [3f82ffcf20] Debug: [web:8080] isPage 1 isAction 0 isUpgrade 0 needsAuthentication 0 isAuthenticated 1 (admin)
2023-08-21 19:27:06_954  [3f82ffcf20] Debug: CWebServer::GetJSonPage :getuptime :/json_htm?type=command&param=getuptime
2023-08-21 19:27:06_957  [3f82ffcf20] Debug: Web ACLF: 192_168_88_102 - - [21/Aug/2023:19:27:06_951 +0300] "GET /json_htm?type=command&param=getuptime HTTP/1_1" 200 92 "http://192_168_88_76:8080/" "Mozilla/5_0 (Windows NT 10_0; Win64; x64) AppleWebKit/537_36 (KHTML, like Gecko) Chrome/115_0_0_0 Safari/537_36 Edg/115_0_1901_203"
2023-08-21 19:27:12_171  [3f7bffef20] Error: mainworker seems to have ended or hung unexpectedly (last update 301_000000 seconds ago)
2023-08-21 19:27:12_173  [3f7bffef20] Error: Domoticz(1259) is exiting due to watchdog triggered___
2023-08-21 19:27:12_290  [3f7bffef20] Error: Failed to start gdb, will use backtrace() for printing stack frame
2023-08-21 19:27:12_890  [3f82ffcf20] Debug: [web:8080] Host:192_168_88_102 Uri:/json_htm?type=command&param=getuptime
2023-08-21 19:27:12_891  [3f82ffcf20] Debug: [web:8080] Request Headers:
Accept: application/json, text/plain, */*
Cookie: DMZSID=705d6529d9c2583e91c4ebfdaee8b45d_OTEzNzAxNTctZDBiYi00NTcyLWEyYzktYzM4MmU1Y2Q0ZGQ0_1692635596
2023-08-21 19:27:12_892  [3f82ffcf20] Debug: SessionStore : get___(705d6529d9c2583e91c4ebfdaee8b45d)
2023-08-21 19:27:12_894  [3f82ffcf20] Debug: [web:8080] CheckAuthToken(705d6529d9c2583e91c4ebfdaee8b45d_OTEzNzAxNTctZDBiYi00NTcyLWEyYzktYzM4MmU1Y2Q0ZGQ0_admin) : user authenticated
2023-08-21 19:27:12_894  [3f82ffcf20] Debug: [web:8080] isPage 1 isAction 0 isUpgrade 0 needsAuthentication 0 isAuthenticated 1 (admin)
2023-08-21 19:27:12_895  [3f82ffcf20] Debug: CWebServer::GetJSonPage :getuptime :/json_htm?type=command&param=getuptime
2023-08-21 19:27:12_897  [3f82ffcf20] Debug: Web ACLF: 192_168_88_102 - - [21/Aug/2023:19:27:12_890 +0300] "GET /json_htm?type=command&param=getuptime HTTP/1_1" 200 91 "http://192_168_88_76:8080/" "Mozilla/5_0 (Windows NT 10_0; Win64; x64) AppleWebKit/537_36 (KHTML, like Gecko) Chrome/115_0_0_0 Safari/537_36 Edg/115_0_1901_203"
2023-08-21 19:27:13_172  [3f85c9d680] Status: Closing application!___
2023-08-21 19:27:13_172  [3f85c9d680] Status: Stopping worker___
2023-08-21 19:27:13_174  [3f80ff8f20] Status: RxQueue: queue worker stopped___
2023-08-21 19:27:13_677  [3f82ffcf20] Status: WebServer(HTTP) stopped
2023-08-21 19:27:13_682  [3f85c9d680] Status: TCPServer: shared server stopped
2023-08-21 19:27:13_682  [3f85c9d680] Status: Stopping all hardware___
2023-08-21 19:27:13_683  [3f827fbf20] Status: Scheduler stopped___
2023-08-21 19:27:13_689  [3f7affcf20] Status: EventSystem: Stopped___
2023-08-21 19:27:13_692  [3f7a7fbf20] Status: EventSystem: Queue thread stopped___
2023-08-21 19:27:13_775  [3f85c9d680] Status: EventSystem - Python stopped___
2023-08-21 19:27:13_776  [3f7b7fdf20] Status: NotificationSystem: thread stopped___
2023-08-21 19:27:13_779  [3f84dfdf20] Status: PluginSystem: Exited work loop_
2023-08-21 19:27:13_882  [3f85c9d680] Status: PluginSystem: Stopped_
2023-08-21 19:27:13_883  [3f817f9f20] Status: Mainworker Stopped___
User defined signal 1
The configuration is clean.
The file "domoticz_crash_log" is empty.
Why is that?
This is similar to the watchdog timer being triggered when the time is updated. But the time is correct.
