Can not add new devices to tab 'Switches'/'Utility'
Eibersite
Post by Eibersite »
I'm running Domoticz 2023.2 on a Raspberry Pi 3b with a ZWave stick and FIBARO devices.
Has worked for a long time but now added 2 devices (Single Switch 2 FGS-213 and a Dimmer 2 FGD-212).
Can see them in the hardware controller and in the devices and here I can also add them (Add Device), but they don't show up in the "Switches"/"Utility" tab.
What's going wrong??
Re: Can not add new devices to tab 'Switches'/'Utility'
Do you have devices attached to user admin or the admin user you have created yourself? See menu Setup- Users, click on assign devices of the admin user. Remove all assigned devices (right column should be empty)
Eibersite
Post by Eibersite »
Walter,
Did what you wrote.
I've never had to in the past.
Thanks, I'm a step further..
Ye, Domoticz keeps changing. And it is also not advised to use an admin account for device sharing.
