A lot of Error: MQTTAuto: unknown idx received! (idx 2661)
Posted: Tuesday 08 August 2023 20:30
by BarryT
Hi all, i'm starting again with some fresh installs...
Now i want to add the MQTT plugin, and its connecting but it keeps saying uknown devices, and so no devices are added.
2023-08-08 18:23:02.539 Status: Domoticz V2023.2 (build 15477) (c)2012-2023 GizMoCuz
2023-08-08 18:23:02.539 Status: Build Hash: 26ebe6e36, Date: 2023-08-05 09:52:15
2023-08-08 18:23:02.539 Status: Startup Path: /home/root/domoticz/
2023-08-08 18:23:02.762 Status: PluginSystem: Started, Python version '3.10.12', 1 plugin definitions loaded.
2023-08-08 18:23:02.805 Status: WebServer(HTTP) started on address: :: with port 80
2023-08-08 18:23:02.850 Status: TCPServer: shared server started...
2023-08-08 18:23:02.851 Status: RxQueue: queue worker started...
2023-08-08 18:23:04.852 Status: NotificationSystem: thread started...
2023-08-08 18:23:04.859 Status: EventSystem: reset all events...
2023-08-08 18:23:04.862 Status: EventSystem: reset all device statuses...
2023-08-08 18:23:04.914 Status: Python EventSystem: Initializing event module.
2023-08-08 18:23:04.916 Status: EventSystem: Started
2023-08-08 18:23:04.916 Status: EventSystem: Queue thread started...
2023-08-08 18:23:05.852 Status: MQTTAuto: Connecting to elektra.bnet:1883
2023-08-08 18:23:06.058 Status: MQTTAuto: connected to: elektra.bnet:1883
2023-08-08 18:23:06.419 Error: MQTTAuto: unknown idx received! (idx 2661)
2023-08-08 18:23:06.520 Error: MQTTAuto: unknown idx received! (idx 2666)
2023-08-08 18:23:06.620 Error: MQTTAuto: unknown idx received! (idx 2330)
2023-08-08 18:23:06.721 Error: MQTTAuto: unknown idx received! (idx 2586)
2023-08-08 18:23:06.821 Error: MQTTAuto: unknown idx received! (idx 2329)
2023-08-08 18:23:11.446 Error: MQTTAuto: unknown idx received! (idx 2403)
2023-08-08 18:23:11.547 Error: MQTTAuto: unknown idx received! (idx 2587)
2023-08-08 18:23:11.647 Error: MQTTAuto: unknown idx received! (idx 2407)
2023-08-08 18:23:28.846 Error: MQTTAuto: unknown idx received! (idx 2635)
2023-08-08 18:23:28.946 Error: MQTTAuto: unknown idx received! (idx 2636)
2023-08-08 18:23:29.046 Error: MQTTAuto: unknown idx received! (idx 2633)
2023-08-08 18:23:30.995 Error: MQTTAuto: unknown idx received! (idx 2639)
2023-08-08 18:23:31.096 Error: MQTTAuto: unknown idx received! (idx 2645)
2023-08-08 18:23:32.645 Error: MQTTAuto: unknown idx received! (idx 2661)
2023-08-08 18:23:32.746 Error: MQTTAuto: unknown idx received! (idx 2666)
2023-08-08 18:23:32.851 Error: MQTTAuto: unknown idx received! (idx 2330)
2023-08-08 18:23:32.951 Error: MQTTAuto: unknown idx received! (idx 2586)
2023-08-08 18:23:33.051 Error: MQTTAuto: unknown idx received! (idx 2329)
2023-08-08 18:23:37.857 Error: MQTTAuto: unknown idx received! (idx 2403)
2023-08-08 18:23:37.958 Error: MQTTAuto: unknown idx received! (idx 2587)
2023-08-08 18:23:38.058 Error: MQTTAuto: unknown idx received! (idx 2407)
2023-08-08 18:23:40.910 Error: MQTTAuto: unknown idx received! (idx 2635)
2023-08-08 18:23:41.010 Error: MQTTAuto: unknown idx received! (idx 2636)
2023-08-08 18:23:41.110 Error: MQTTAuto: unknown idx received! (idx 2633)
2023-08-08 18:23:41.211 Error: MQTTAuto: unknown idx received! (idx 2639)
2023-08-08 18:23:41.311 Error: MQTTAuto: unknown idx received! (idx 2645)
2023-08-08 18:23:42.648 Error: MQTTAuto: unknown idx received! (idx 2661)
2023-08-08 18:23:42.748 Error: MQTTAuto: unknown idx received! (idx 2666)
2023-08-08 18:23:42.857 Error: MQTTAuto: unknown idx received! (idx 2330)
2023-08-08 18:23:42.957 Error: MQTTAuto: unknown idx received! (idx 2586)
2023-08-08 18:23:43.058 Error: MQTTAuto: unknown idx received! (idx 2329)
2023-08-08 18:23:47.478 Error: MQTTAuto: unknown idx received! (idx 2012)
2023-08-08 18:23:47.579 Error: MQTTAuto: unknown idx received! (idx 2013)
2023-08-08 18:23:47.679 Error: MQTTAuto: unknown idx received! (idx 2011)
Someone knows whats going on here?
Re: A lot of Error: MQTTAuto: unknown idx received! (idx 2661)
Posted: Tuesday 08 August 2023 20:32
by jvdz
Assume you are pointing to an existing MQTT server that is receiving live data for existing devices in another domoticz setup which also is using domoticz/in topic to listen too? (Sam answer as i just typed in PM ;) )
Posted: Tuesday 08 August 2023 20:33
by BarryT
jvdz wrote: Tuesday 08 August 2023 20:32 Assume you are pointing to an existing MQTT server that is receiving live data for existing devices in another domoticz setup which also is using domoticz/in topic to listen too? (Sam answer as i just typed in PM ;) )
I'm connecting to my mqtt (mosquitto) broker server on port 1883.
i guesss i have to say yes i'll do, since there are 2 other domoticz devices connected to this broker..
Posted: Tuesday 08 August 2023 20:34
by jvdz
understood, but is this a new one mosquitto server or one used by another domoticz instance already?
So, how do you seperate the messages for the different Domoticz systems as they all listen to DOMOTICZ/IN by default
Posted: Tuesday 08 August 2023 20:35
by BarryT
jvdz wrote: Tuesday 08 August 2023 20:34 understood, but is this a new one mosquitto server or one used by another domoticz instance already?
its just a new, fresh install of domoticz wich i want to "remote" mqtt my devices that already adopted in the mqtt/conbee on my broker
(my other 2 domoticz raspberry's are working to as well on this mqtt broker)
Posted: Tuesday 08 August 2023 20:38
by jvdz
Understood... but think about this for a little! :)
Your MQTT broker is nothing more or less than a store and forward of messages, so when all your 3 domoticz servers "listen" to the same "domoticz/in" topic, they will all try to process any message dumped in that topic! So you new system will try to process all messages that are directed to your current setup and thus generate a shitload of unknows as none of the devices is known.... right?
by BarryT
good question... i just want to add the devices that already in there to use them from another domoticz. lol
Posted: Tuesday 08 August 2023 20:40
by jvdz
That could be done, but that would mean the have to have the exact same devices list! ;)
Posted: Tuesday 08 August 2023 20:41
by BarryT
jvdz wrote: Tuesday 08 August 2023 20:38 Understood... but think about this for a little! :)
Your MQTT broker is nothing more or less than a store and forward of messages, so when all your 3 domoticz servers "listen" to the same "domoticz/in" topic, they will all try to process any message dumped in that topic! So you new system will try to process all messages that re directed to your current setup and thus generate a shitload of unknows as none of the devices is known.... right?
i think this will be the thing, yes?
but the weird thing is, when using the mqqt-AD plugin, nothing come in, no log, no devices.
i tried homeassistant / domoticz / and some other, nothing.
when using the mqtt-gateway plugin, i'm getting those errors about the unknown devices.
On my other (older) domoticz it worked directly?
by BarryT
jvdz wrote: Tuesday 08 August 2023 20:40 That could be done, but that would mean the have to have the exact same devices list! ;)
okay... but how?
Posted: Tuesday 08 August 2023 20:45
by jvdz
For any devices used by MQTT-AD, there won't be an issue as the AD part will generate the devices and then point that to the appropriate MQTT topic for the status updates. So this issue is for any device you have out there that does updates via MQTT to topic domoticz/in.
So that probably is the safe way of doing this when starting form scratch, as those other devices have hardcoded IDX devices.
In case you really want to start with the existing set of devices, you "simply" import the existing database from the old system.... but that means you get it all!!!! Current Hardware/Devices/History ...etc etc
Posted: Tuesday 08 August 2023 20:48
by BarryT
Hmm.. that database is only 158mb of devices and stuff, is it not possible to only get idx devices?
Posted: Tuesday 08 August 2023 20:50
by BarryT
i was hoping that after adding the plugin my devices where come in, but it didnt :( grr...
none on topic homeassistant, none (only errors) on topic domoticz, etc..
then why is this plugin exactly made for?
Posted: Tuesday 08 August 2023 20:54
by jvdz
So using the standard functionality the answer is no, but the db is sqlite so anything is possible when you put your mind to it, ..... but you should ask yourself whether you want to go down that road full of potholes? ;)
As stated, anything that is using the buildin MQTT-Auto discovery will be properly generated and data will flow! This is about any updates via DOMOTICZ/IN.
Not sure how the (MQTT?) plugin works, so can't speak to that.
Posted: Tuesday 08 August 2023 21:06
by BarryT
So when using homeassistant, everything works correctly like it should but in Domoticz its not possible?
Posted: Tuesday 08 August 2023 21:09
by BarryT
I just want to add the devices that are in topic homeassistant on my broker (like most do), so this is not possible?
In My ha setup everything is coming in, exactly what i want but i need them in Domoticz, not in ha?
Posted: Tuesday 08 August 2023 21:48
by jvdz
I've tried to explain why you get these LOG messages assuming the do come from the domoticz/in topic.
There is no relation to AutoDiscovery for devices, which also should work fine in Domoticz when configured correctly.
