Intergration zwave js ui with domoticz
rron
Post by rron »
Maybe is this a stupid remark but what is the reason that zwave js ui is not fully integrated with domoticz like it is on HA or like zwave use to be on domoticz?
The reason that I ask this is that the installation is easier than what it is right now, only one docker installation instead of two. ;)
jvdz
Domoticz version: 4.107
Re: Intergration zwave js ui with domoticz
Post by jvdz »
...because nobody build that for Domoticz (yet)!?
Fancy a nice challenge?
Which part makes it easier than the current auto discovery implementation?
rron
Post by rron »
Hello Jos,
If i had the knowledge i should really try that. 8-) My skills are electronics and not software like yours.
The part of installing only one docker instead of two makes it easier and of you don’t use docker you have just one script like it use to be with zwave.
You can also ask the question why is it separated from domoticz in the first place.
rron
Post by rron »
jvdz wrote: Friday 04 August 2023 13:50 ...because nobody build that for Domoticz (yet)!?
I installed HA as a test and noticed that the basic application such as zwave jsui where included and that makes life more easy and less complicated.
I will stay at domoticz because of all my dedicated automation scripts that i hav e collected through the years.
