Question about DIAL
Posted: Thursday 03 August 2023 20:44
by abone
I'm trying to setup a Dial and I have a question:
blocks['Energy'] = {
idx: '26181',
title: 'Conso',
type: 'dial',
value: 'Usage',
It reports the right number as 'kwh' instead of 'wh'
Even If I use:
unit: 'wh',
It still reports in 'kwh'.
If I dig in </> show data, I get :
"Usage": "216,909 Watt",
(I had to put a coma because the forum complain but it is a dot)
Thanks for your help !
Re: Question about DIAL
Posted: Thursday 03 August 2023 21:25
by Lokonli
abone wrote: Thursday 03 August 2023 20:44 Hi,
idx: '26181',
title: 'Conso',
type: 'dial',
value: 'Usage',
Even If I use:
unit: 'wh',
What kind of Domoticz device type are you using?
Posted: Thursday 03 August 2023 22:59
by abone
Thanks for asking. It's the 'Aeon Lab Home Energy Meter ZW095'.
cheers
Posted: Saturday 05 August 2023 11:17
by abone
Sorry I have corrected, I initialy wrote Aeotec instead of Aeon Lab :(
So it is the Aeon Lab Home Energy Meter (ZW095).
Posted: Sunday 06 August 2023 12:54
by Lokonli
abone wrote: Saturday 05 August 2023 11:17 Sorry I have corrected, I initialy wrote Aeotec instead of Aeon Lab :(
In Domoticz this probably is an energy device. To be sure, can you post the output of:
http://domoticz:8080/json.htm?type=devices&rid=26181
For Energy devices normally the field 'Usage' gives the actual power usage (in W). The total energy usage is provided via 'CounterToday' (in kWh)
Energy devices are handled in a specific way. Not all configuration parameters are used. Normally an Energy dial will display the daily counter as the big number (in kWh) and the actual usage (in W) as a small number below. You can switch this by adding the following as block parameter:
   subtype: 'usage'
Example:
If you want to customize your dial, you can do it as follows:
    idx: 26181,
    type: 'dial',
    title: 'Conso',
    showvalue: false,
    values : [
            value: 'Usage',
            unit: 'W',
            addClass: 'primary'
            value: 'CounterToday',
            unit: 'kWh'
