Dear friends,
Installed new version of Domoticz
Tabs changed:
Utility, Devices and Setup not there.
Version: 2023.2
Build Hash: 19efd039c
Compile Date: 2023-07-21 17:23:44
dzVents Version: 3.1.8
Python Version: None
Active User: admin
Devices and Hardware setup tabs not visible or accesible
- Domoticz version: 2026.3
Re: Devices and Hardware setup tabs not visible or accesible
Did you search this forum?
User setup has changed (since 2023.1) so please check your user settings for tabs in menu setup users.
And if already correct please clear your browser cache.
I have no setup or devices tabs
I am in "user" mode and forgot my admin password in Domoticz itself,
trying to figure out how to revive or change that passwrd.
Most likely the tabs will then appear
thnx in advance,
thnx in advance,
See the wiki https://www.domoticz.com/wiki/Lost_Username_Password
root@orangepione:~# cd /home/domoticz/domoticz
root@orangepione:/home/domoticz/domoticz# ./domoticz -nowwwpwd
2023-07-31 15:02:54.129 Status: Domoticz V2023.2 (c)2012-2023 GizMoCuz
2023-07-31 15:02:54.129 Status: Build Hash: 19efd039c, Date: 2023-07-21 17:23:4 4
2023-07-31 15:02:54.129 Status: Startup Path: /home/domoticz/domoticz/
2023-07-31 15:02:54.155 Error: Default admin password has NOT been changed! Cha nge it asap!
2023-07-31 15:02:54.171 Sunrise: 05:59:00 SunSet: 21:35:00
2023-07-31 15:02:54.171 Day length: 15:36:00 Sun at south: 13:47:00
2023-07-31 15:02:54.171 Civil twilight start: 05:17:00 Civil twilight end: 22:1 7:00
2023-07-31 15:02:54.171 Nautical twilight start: 04:19:00 Nautical twilight end : 23:14:00
2023-07-31 15:02:54.171 Astronomical twilight start: 02:51:00 Astronomical twil ight end: 00:42:00
2023-07-31 15:02:54.171 Status: PluginSystem: Failed dynamic library load, inst all the latest libpython3.x library that is available for your platform.
2023-07-31 15:02:54.188 Active notification Subsystems: (0/13)
2023-07-31 15:02:54.190 Status: WebServer(HTTP) started on address: :: with por t 8080
2023-07-31 15:02:54.193 Error: SECURITY RISK! Allowing access without username/ password as all incoming traffic is considered trusted! Change admin password as ap and restart Domoticz!
2023-07-31 15:02:54.210 Status: WebServer(SSL) started on address: :: with port 443
2023-07-31 15:02:54.213 Error: SECURITY RISK! Allowing access without username/ password as all incoming traffic is considered trusted! Change admin password as ap and restart Domoticz!
2023-07-31 15:02:54.216 Starting shared server on: :::6144
2023-07-31 15:02:54.217 Status: TCPServer: shared server started...
2023-07-31 15:02:54.217 Status: RxQueue: queue worker started...
2023-07-31 15:02:56.218 Status: P1: Using serial port: /dev/ttyUSB0
2023-07-31 15:02:56.257 Status: P1: Using serial port: /dev/ttyUSB0
2023-07-31 15:02:56.256 Status: P1: Worker started...
Seem OK now. standard user/password combo admin/domoticz should work now if you stop this manual domoticz process and start domoticz from services.
