[SOLVED] Zigbee for Domoticz : object has no attribute 'load_network_info'
Posted: Tuesday 25 July 2023 12:50
by urlu75
solved : flashing firmware 6. 10. 3
juste made a fresh install of the OS (32bits) and Domoticz on a rpi4.
SONOFF zigbee 3 is not working.
PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
NAME="Raspbian GNU/Linux"
VERSION_ID="11"
VERSION="11 (bullseye)"
VERSION_CODENAME=bullseye
ID=raspbian
ID_LIKE=debian
I can't make the Zigbee USB dongle to start correctly with Domoticz.
Having this error :
 Transport mode: ZigpyZNP
 Start Zigpy Transport on ZNP
 Starting radio znp port: /dev/ttyACM0
 ZigpyTransport: thread_processing_and_sending Thread start.
 Start Web Server connection
 Web backend for Web User Interface started on port: 9440
 Plugin looks to upgrade the Certified Device package
 Started radio znp port: /dev/ttyACM0
 Domoticz Widgets usage is at 1 .2 % (252 units free)
 Network settings
 Device IEEE: ff:ff:ff:ff:ff:ff:ff:ff
 Device NWK: 0xFFFE
 Network Update Id: 0x0000
 PAN ID: 0xFFFE
 Extended PAN ID: ff:ff:ff:ff:ff:ff:ff:ff
 Channel: 0
Error at startup 'NoneType' object has no attribute 'load_network_info'
Coordinator not correctly initialized
And here is the log from the DZ console :
0: Object {"Time":"25/07/2023 12:18:22","Module":"TransportZigpy","nwkid":"None","PluginHealth":"Startup","message":"Error at startup 'NoneType' object has no attribute 'load_network_info'","PermitToJoin":{"Duration":0,"Starttime":0},"Thread":"ZigpyCom_2"}
1:
Time: "25/07/2023 12:18:22"
Module: "Input"
nwkid: "None"
PluginHealth: "Startup"
message: "Coordinator not correctly initialized"
PermitToJoin: Object {"Duration":0,"Starttime":0}
Thread: "ZigpyForwarder_2"
LastLog: 1
StartTime: "25/07/2023 12:18:11"
FirmwareVersion: null
FirmwareMajorVersion: null
PluginVersion:
0: "stable7 - 7 . 1 .001"
Any idea of what is the load_network_info and how to make the gateway start ?
Thanks for your help
