Enphase counters how to fix after update from 5x to 7x
Posted: Wednesday 19 July 2023 9:55
by hemant5400z
Hi All,
I just got upgraded from 5x to 7x so i now need to use tokens. I have created the tokend and enabled this in my device and updated the plugin with username and pw. My previous device is updated. "Enphase Kwh Production" General Kwh. However I also had a Enphase Production Kwh Total which kept track of the total Meter stats, this one is not getting updated anymore. Looks like there is no P1 Smartmeter device for enphase anymore?
Does anyone know wher to get the Totals from as i'm keeping track of the total production during lifecycle so i can measure by month and year.
Thanks Hemant.
Re: Enphase counters how to fix after update from 5x to 7x
Posted: Wednesday 19 July 2023 15:41
Check your unused devices (menu Setup - Devices), there is an Enphase Kwh Production device that is showing the data. P1 meter is indeed not used anymore, see also the wiki:
https://www.domoticz.com/wiki/Enphase
The Enphase Kwh Production device also will show the totals per day/week/month/year if you go to the device log and report page.
Posted: Wednesday 19 July 2023 19:18
by hemant5400z
Hi do you know which field?
In have an envoys-s not metered. I checked with sql my lifetime value is 8000 kwh +. However i cannot see that value in the miltimeter nor multimeter_calender.
So not sure where it is storing my lifetime now. De kwh total old version stopped increasing and hangs arousn 8000 kwh
Hemant
Posted: Wednesday 19 July 2023 20:18
Check in menu setup devices the devices that are connected to the Enphase hardware gateway. There should be a counter device that is updated. See also the wiki for an example. No need to check the tables.
Also update to the latest beta version.
Posted: Wednesday 19 July 2023 20:42
by hemant5400z
Enohase device wich shows me inatant production there is no counter for total in devices neither in unused devices for enohase i have one main device and all individual solar panels.
Im missing the devices as in orevious versions where the current lifetime counter is showing.
Hemant
by hemant5400z
Hemant
Posted: Thursday 20 July 2023 0:26
That device is no longer present, but the data is in the instant production device. Click on log button and then report.button top right corner.
Posted: Thursday 20 July 2023 9:51
by hemant5400z
Just checked but it is not in sync with my enphase:
Total Generated: 4209.982 kWh
Counter: 728.182 kWh
Year Earnings: 885.78
While Enlighten shows correct 9.1 MW. SO the copunter value is not correct. However when i logon locally I see the counter value on the main page.
Any idea why it is showing wrong?
Hemant
Posted: Friday 21 July 2023 0:32
The total generated data is the generated data available in Domoticz for the selected year, currently 2023. You can select another year eg 2022 to see the totals of that year.
Posted: Thursday 27 July 2023 12:57
by hemant5400z
Hi back again,
So I did some testing with the plugin, for some reason Domoictz takes a different counter which is current around 800 kwh.
I checked with HA and the plugin there takes a different counter which shows me the correct liftetime value as expected.
Does anyone know why?
Hemnt
Posted: Thursday 27 July 2023 20:36
Perhaps related to this issue?
https://github.com/domoticz/domoticz/issues/5734
Edit: and also check this forum topic:
viewtopic.php?t=31959
Posted: Friday 28 July 2023 0:27
by hemant5400z
Checked both topics but there is no solution mentioned.
Hemant
