P1 no negative value
tiga
Post by tiga »
My friend has a raspberry connected to the p1 port of a 3 fase meter.
In the mobile app the actual value does not show a negative value when solarpanels produce more than the deliverd power of the grid.
The value Just show 0
How is this possible?
My p1 shows a negative value.
FireWizard
Re: P1 no negative value
Post by FireWizard »
What are the software versions of both your Domoticz and the one of your friend?
tiga
Post by tiga »
Both running last stable Version.
It is only 0 in the mobile app
On the web page it is showing a negative value
FireWizard
Hi, @tiga,
I suggest you open a new issue on Github for this application, as It seems not to be a Domoticz issue.
I assume you both use the same version of the Android app?
See: https://github.com/domoticz/domoticz-android
