Softly switching off a light (newbie Q)
Posted: Saturday 10 June 2023 14:40
by athoopen
All,
I could do with some help. I created a script that softly switches off a light by gradually reducing the brightniss:
domoticz.devices(2002).setColorBrightness(255,255,255,100).afterSec(1)
domoticz.devices(2002).setColorBrightness(255,255,255,99).afterSec(2)
domoticz.devices(2002).setColorBrightness(255,255,255,98).afterSec(3)
domoticz.devices(2002).setColorBrightness(255,255,255,2).afterSec(98)
domoticz.devices(2002).setColorBrightness(255,255,255,1).afterSec(99)
domoticz.devices(2002).switchOff().afterSec(100)
But honestly ... isn't there a more proper/nicer/better/easier way to do this?
All help appreciated,
Re: Softly switching off a light (newbie Q)
Posted: Saturday 10 June 2023 15:54
by Kedi
It depends on the kind of device(s) and type of devices you have.
On some Zigbee device there is a transition setting and/or brightness_move_onoff setting.
And of course you could the "domoticz.devices(2002).setColorBrightness(255,255,255,100-x).afterSec(x)" in a loop
Posted: Saturday 10 June 2023 16:21
by athoopen
Thanks @Kedi. The lights are Wi-Fi lights from the Action. Have to do it all "manually" (to my knowledge)
I did think about looping, but I couldn't find any instructions/examples on how to do looping in dzvents.
Could you give me an example, or point me to examples/instructions/documentation?
TIA!
Posted: Saturday 10 June 2023 17:14
by Kedi
Try Google with "lua loop" and you get a lot of hits with examples you could use in dzVents.
Posted: Saturday 10 June 2023 17:28
by mvveelen
Not tested (I have Hue lights and they have a setting for it), but something like this?
local device = domoticz.devices(2002)
for brightness = 100, 1, -1 do
device.setColorBrightness(255, 255, 255, brightness).afterSec(100 - brightness)
Posted: Saturday 10 June 2023 20:34
by athoopen
Thanks, only looked at the docs of dzvents, not lua. Example was a great starting point, got it all working now!
Posted: Sunday 18 June 2023 16:47
by athoopen
I still could do with some help since I try to create a global function to softly switch off a light. The trouble I have is that it returns an error and I have no clue what I am doing wrong.
This is the global function I created:
-- global persistent data
data = {
myGlobalVar = { initial = 12 }
-- global helper functions
helpers = {
myHelperFunction = function(domoticz)
-- code
end,
LightSoftOn = function (domoticz, idx)
-- os.execute("/usr/local/bin/telegramsend Execute LightSoftOn for " .. IDX)
for brightness = 0, 100, 1 do
domoticz.devices(idx).setColorBrightness(255, 255, 255, brightness).afterSec(brightness)
return true
end,
LightSoftOff = function (domoticz, idx)
-- os.execute("/usr/local/bin/telegramsend Execute LightSoftOff for " .. idx)
for brightness = 100, 0, -1 do
domoticz.devices(idx).setColorBrightness(255, 255, 255, brightness).afterSec(100 - brightness)
domoticz.devices(idx).switchOff().afterSec(idx)
return true
end,
and here how I call it:
timer = {
'every 2 minutes',
logging = {
level = domoticz.LOG_INFO,
marker = 'TEST',
execute = function(domoticz, timer)
-- local Lamp = domoticz.devices(2002)
LightSoftOff (domoticz, 2002)
Which results in the error:
2023-06-18 16:46:00.500 Error: dzVents: Error: (3.1.8) TEST: An error occurred when calling event handler XYZtest
2023-06-18 16:46:00.500 Error: dzVents: Error: (3.1.8) TEST: ...i/domoticz/scripts/dzVents/generated_scripts/XYZtest.lua:14: attempt to call a nil value (global 'LightSoftOff')
What am I doing wrong?? All help is appreciated!
Posted: Monday 19 June 2023 9:31
by Kedi
What I do in such cases is that I put this line as the first line in the script.
local dg = require ("global_data")
After that you can access all data and functions with something like:
I do this so that in the source it will be visible where the data or function comes from.
Re: Softly switching off a light (newbie Q) [SOLVED]
Posted: Monday 19 June 2023 10:17
by athoopen
@Kedi: require did the trick!! Thanks again.
