Heating finally automated using HomeEasy HE105
Posted: Tuesday 18 November 2014 23:49
Hi All,
Latest Version of the code updated : 10/03/2015 V0.4 <- Latest version updated to support new temperature set point switch. this removes the need for lots of the code and additional switches. Enjoy
I thought I'd share as I finally managed to get my heating hooked up to Domoticz. I know some of you already have something like this but I'm well pleased now I have it working. See below a screenshot and code for anyone who wants it. Have fun.
Hardware:
Woostesher Bosch CDi 30 - Link: http://www.worcester-bosch.co.uk/homeow ... sic-system
Homeeasy 105 Switch (Currently on sale - http://www.domoticz.com/forum/viewtopic.php?f=18&t=4028)
rfxtrx & pi
Latest Version of the code updated : 08/11/2015 V0.4.1
-- Version 0.3
Wiring (Get this checked by someone qualified. Just sharing for info
special thanks goes out to my mate Kenny who helped me here
This is the inside of the Homeeasy HE105 and what I hooked it up to on the Boiler (see the boiler manual for info on the other connections). So once I hooked this up I left the digistat that came with the boiler attached but just turned it all the way up to max so Domoticz can control the heating and I don't have to worry too much about connecting everything back up when I move out.
Hardware:
rfxtrx & pi
-- Heating Control
-- Version 0.4.1
-- Author - Martin Rourke
-- This library is free software: you can redistribute it and/or modify it under the terms of
-- the GNU Lesser General Public License as published by the Free Software Foundation, either
-- version 3 of the License, or (at your option) any later version. This library is distributed
-- in the hope that it will be useful, but WITHOUT ANY WARRANTY; without even the implied
-- warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU Lesser General
-- Public License for more details. You should have received a copy of the GNU Lesser General
-- Public License along with this library. If not, see <http://www.gnu.org/licenses/>.
-- Setup
-- To use this script you need to have a few devices already setup in Domoticz
-- 1. A physical switch to operate (On/Off Switch)
-- 2. A physical temperature sensor (Temperature)
-- 3. A virtual switch to tun on and off the heating (On/Off Switch)
-- 4. A virtual switch to set the target temperature (Temperature)
-- 5. Define a User Variable as 'Debug', Integer and set to 1 or 0 to show/hide entries in the log
local physicalheater = 'Heating House (Boiler)'
-- Future improvement will be to define more than one temperature sensor and assume an average
local currenttemperature = 'Temperature Bedroom'
local virtualheater = 'Heating House'
-- Assumes you are using a dummy switch "Thermostat Setpoint" to move temperature up and down
local targettemperature = 'Thermostat House'
-- 5. UserVariable - Set debug to 1 for testing. 0 for live running.
-- OPTIONS
-- Defines the amount the target temperature will move when the up and down buttons are pressed
local pitch= 1
-- The tolerance for the thermostat. So the heating doesn't continually turn on and off around
-- the target temperature this specifies the tolerance before any action is taken.
local tolerance = 0.5 -- NOT BEING USED!!!!!
-- After this time the heating will automatically turn off as a temperature was not detected
-- from the temperature sensor. this helps protect against the heating being left on all the
-- time if the signal is lost.
local lostsignaltime = 3600 -- 60 minutes
-- Helps protect against multiple quick changes to the physical switch
local heatercommanddelay = 30 -- 30 seconds
-- Repeats the On or Off command after a set time for devices that don't have a handshake
-- Should always be bigger than heatercommanddelay
local heaterrepeatdelay = 60 -- 1 minute
-- NOTHING SHOULD NEED TO CHANGE BELOW THIS LINE
local thermostatchgnagedetected = 0
function debuglog (s)
if uservariables["Debug"] == 1 then print("DEBUG - THERMOSTAT " .. physicalheater .. s) end
return true
function timedifference (s)
year = string.sub(s, 1, 4)
month = string.sub(s, 6, 7)
day = string.sub(s, 9, 10)
hour = string.sub(s, 12, 13)
t1 = os.time()
return difference
-- Controls the heating based on the target and current temperatures
-- Is the heating scheduled to be on?
if (otherdevices[virtualheater]=='On') then
debuglog('Heating - Heating Is Scheduled To Be On: ' .. virtualheater )
-- what is the target temperature?
target = tonumber(otherdevices_svalues[targettemperature])
-- test to see if we can still see the thermostat. If not force the heating off
--debuglog('Heating - Control Switch: ' .. tostring(timedifference(otherdevices_lastupdate[currenttemperature])) .. ' LostSignalTime: ' .. tostring(lostsignaltime))
if ( timedifference(otherdevices_lastupdate[currenttemperature]) > lostsignaltime ) then
debuglog('Heating - WARNING: Last seen temperature sensor: '.. currenttemperature ..' ' .. tostring(otherdevices_lastupdate[currenttemperature]))
debuglog('Heating - WARNING: Signal Lost with temperature sensor for over '.. lostsignaltime ..' seconds: '.. currenttemperature)
debuglog('Heating - WARNING: forcing Heating OFF : '.. physicalheater)
if( timedifference(otherdevices_lastupdate[physicalheater]) > heaterrepeatdelay) then -- checks to see if the command needs to be repeated
if (otherdevices[physicalheater]=='Off') then
debuglog('Heating - WARNING - Turning Physical Heater On: '.. physicalheater)
debuglog('Heating - WARNING - Turning Physical Heater On (Repeat Command): '.. physicalheater)
commandArray[physicalheater] = 'On'
debuglog('Heating - INFO: Not enough time has passed before issuing repeat command to switch: Only '.. timedifference(otherdevices_lastupdate[physicalheater]) .. ' seconds out of ' .. heaterrepeatdelay .. ' seconds')
debuglog('Heating - Last seen temperature sensor: '.. currenttemperature ..' ' .. tostring(otherdevices_lastupdate[currenttemperature]))
-- What is the current temperature?
--debuglog('STRING 1 Current - Return Value : ' .. tostring(otherdevices_svalues[currenttemperature]))
--debuglog('STRING 2 Current - Value Type : ' .. type(otherdevices_svalues[currenttemperature]))
--debuglog('STRING 3 Current - First Element : ' .. string.gmatch(otherdevices_svalues[currenttemperature], '([^;]+)')(1))
-- As some temperature devices also return other values as humidity this assumes the first value is the temperature in all cases
current = tonumber(string.gmatch(otherdevices_svalues[currenttemperature], '([^;]+)')(1))
debuglog('Heating - Target: ' .. tostring(target) .. ' Current: ' .. tostring(current))
if( timedifference(otherdevices_lastupdate[physicalheater]) > heatercommanddelay ) then -- checks to see if the heater has been turned off recently
debuglog('Heating - Enough time has passed since last change to switch: '.. timedifference(otherdevices_lastupdate[physicalheater]) .. ' seconds out of ' .. heatercommanddelay .. ' seconds')
if (current < target) then
debuglog('Heating - Turning Physical Heater On: '.. physicalheater)
if( timedifference(otherdevices_lastupdate[physicalheater]) > heaterrepeatdelay or devicechanged[remoteup] or devicechanged[remotedown] or devicechanged[virtualheater]) then -- checks to see if the command needs to be repeated
debuglog('Heating - Turning Physical Heater On (Repeat Command): '.. physicalheater)
debuglog('Heating - Turning Physical Heater Off: '.. physicalheater)
if (otherdevices[physicalheater]=='On') then
debuglog('Heating - Turning Physical Heater Off (Repeat Command): '.. physicalheater)
commandArray[physicalheater] = 'Off'
debuglog('Heating - INFO: Not enough time has passed before issuing command to switch: Only '.. timedifference(otherdevices_lastupdate[physicalheater]) .. ' seconds out of ' .. heatercommanddelay .. ' seconds')
debuglog('Heating - Turning Heating Off As Scheduled To Be Off')
if( timedifference(otherdevices_lastupdate[physicalheater]) > heatercommanddelay ) then -- NEED SOMETHING IN HERE TO STOP TURNING ON AND OFF CONSTANTLY
debuglog('Heating - Enough time has passed before issuing command to switch: '.. timedifference(otherdevices_lastupdate[physicalheater]) .. ' seconds out of ' .. heatercommanddelay .. ' seconds')
endCode: Select all
-- Heating Control
-- Version 0.3
-- Setup
-- 5. A virtual switch to move the target temperature up (Push Button)
-- 6. A virtual switch to move the target temperature down (Push Button)
local physicalheateridx = 181
-- This is the name and idx of the REAL temperature sensor you want to use to monitor the
-- temperature. Virtual Temperature Sensor - name and id
--local currenttemperature = 'Temperature Kitchen'
--local currenttemperatureidx = 3
--local currenttemperature = 'Temperature Hall'
--local currenttemperatureidx = 111
local currenttemperatureidx = 2
local virtualheateridx = 178
local targettemperatureidx = 172
local remoteup = 'Thermostat House Up'
local remotedown = 'Thermostat House Down'
-- OPTIONS
local pitch= 1
local heaterrepeatdelay = 600 -- 1 minute
-- Set debug to 1 for testing. 0 for live running.
debug = 0 -- Stored as variable now
--if debug == 1 then print(s) end
--print "DEBUG"
if uservariables["Debug"] == 1 then print("DEBUG - THERMOSTATHOUSE " .. " " .. s) end
return true
t1 = os.time()
return difference
-- Actions for moving the target temperature up and down
if (devicechanged[remoteup] or devicechanged[remotedown]) then
debuglog('Thermostat - Target Temperature: ' .. tostring(target))
if (devicechanged[remoteup]=='On') then
commandArray['UpdateDevice'] = targettemperatureidx .. '|0|' .. tostring(target+pitch)
commandArray[remoteup] = 'Off'
debuglog('Thermostat - Target Temperature Up by : ' .. tostring(pitch) .. ' to : ' .. tostring(target+pitch))
elseif (devicechanged[remotedown]=='On') then
commandArray['UpdateDevice'] = targettemperatureidx .. '|0|' .. tostring(target-pitch)
commandArray[remotedown] = 'Off'
debuglog('Thermostat - Target Temperature Down by : ' .. tostring(pitch) .. ' to : ' .. tostring(target-pitch))
debuglog('Thermostat - Target Temperature: ' .. tostring(target) .. '')
debuglog('Heating - WARNING: Signal Lost with temperature sensor for over '.. lostsignaltime ..' seconds: '.. currenttemperature .. ' (IDX: '.. currenttemperatureidx ..')')
-- commandArray['SendNotification']='Test' -- SEND NOTIFICATION
-- what is the current temperature?
