Different working mode for commandArray since some versions Topic is solved
Thorgal789
Post by Thorgal789 »
Hello IDK if it's normal but since some version I have a curious issue.
I have some dimmable light that have stoped working with
commandArray['Deconz - Dimmer salon'] = 'off'
But still working with
commandArray['Deconz - Dimmer salon'] = 'Set Level: 0'
It's normal ? I have same issue for "on" ofc, and it's here the problem, for "off" I can use this workaround.
Thorgal789
Re: Different working mode for commandArray since some versions
I m the only one with this change ? So the problem is from my side ?
HansieNL
Post by HansieNL »
I'm not sure if on/off is case sensitive On/Off.
Can you try with capital O?
Blah blah blah
Thorgal789
IDK what was happen, was an old script, so haven't changed it.
But you are right, it have worked with "On" and "Off"
Thx, I have spent perhaps 1h on it .......
psubiaco
Post by psubiaco »
Any device in Domoticz has:
* one integer value (usually set to 0=OFF, 1=ON, and 10=Level1 20=Level2 for selector switches)
* one string value, that can store many information, for example "Value1;Value2;Value3;..." for devices like Temp+Hum, meters, ...
You can check this, using a lua script, printing the value of
otherdevices["Deconz - Dimmer salon"]
otherdevices_svalues["Deconz - Dimmer salon"]
When you set commandArray["Deconz - Dimmer salon"]="Set Level 80"
automatically domoticz set the value to 80% and set the integer value to 1 (On).
When you set commandArray["Deconz - Dimmer salon"]="Set Level 0"
automatically domoticz set the value to 0% and set the integer value to 0 (Off).
Maybe this can help you finding the problem?
Please note that in my scripts I do not separate the level value by ":" but I just write "Set Level N"
You can find some scripts examples here: https://github.com/CreasolTech/domoticz_lua_scripts
Good luck
Paolo
Thorgal789
Ok so the bug is back.
And it's not from code.
I need to restart domoticz for LUA script are able to send commandArray. I think the last time I have restarted too.
Still on investigation.
