Domoticz version: 2023.1 Build 15248
Hardware :Visual Crossing Weather app
Dear community does anyone know why the Wind sensor is visualized as a temperature sensor under 'Temperature' and not visible under the Weather TAB which I would expect for Wind. Within the 'Devices' menu the 'Log' button on the right-hand side visualizes the correct Wind graphs for speed, direction and gust.
If anyone has a solution for this then I'm happy to hear how to get the Wind sensor properly added, with the values I'm steering my sunscreens to go up when wind speeds are to high.
Thank you in advance.
Wind measurement picked up as Temperature sensor Topic is solved
- Mooms
- Domoticz version: 2023.01
- 2023-05-22 12_52_25-Clipboard.png (161.77 KiB) Viewed 5110 times
- Domoticz version: 2026.3
Re: Wind measurement picked up as Temperature sensor
This is because the wind sensor also has temperature information. So the temperature part of the windsensor is then shown in the temperature section.
- Mooms
The issue has already resolved itself as I was apparently too inpatient as I now see new devices added to the 'Weather' tab with Wind as a separate sensor.Mooms wrote: Monday 22 May 2023 13:03 Domoticz version: 2023.1 Build 15248
ssk17051980
- Domoticz version: 2023.2
What wind sensor do you use ?
As stated in the start topic the Visual crossing web application https://www.domoticz.com/wiki/Visual_Cr ... her_lookup
