Combine groups and scenes for the same lights
Posted: Thursday 11 May 2023 12:01
I have 3 dimmable lights in my living room, all connected to a separate fibaro 2 dimmer.
One of them is my "main" light, meaning that when I switch that one on (either via domoticz or the light switch) I want all the other lights to go on as well (with a set dim level), and also off when the main light is turned off. I created a group for that with the main light as trigger and that works well.
However for some occasions (like for instance watching a movie) I want to set all those 3 lights to a different dim level . The problem is that I can not do that with a scene because the "main" light is already the trigger for the defined group and then will not work in a scene.
I could create a DSVentz script checking the dim level of the main light and set the other 2 lights accordingly, but I wondered if there isn't a nicer way of doing this without a script?
