Fibaro FGMS001 Motion Sensor - Temperature Not Showing
Posted: Tuesday 18 November 2014 17:10
by geoffnewnham
have added a Fibaro FGMS001 Motion Sensor to my Domoticz, V2.2121, all sensors added and showing ok except the Temperature sensor, Any ideas on how I can get Temp Sensor to show up? :shock:
Best Regards
Geoff
Re: Fibaro FGMS001 Motion Sensor - Temperature Not Showing
Posted: Thursday 27 November 2014 13:14
by willie-p
Geoff,
I got my Fibaro FGMS-001version 2.6 yesterday and had the same problem.
After a while all the sensors came visible.
If the problem still exists perhaps re-include will work?
Cheers,
Will
Posted: Thursday 27 November 2014 20:36
by micha_pr
Should work.
Try to reinclude (include again, then will be the ID the same) or wakeup the device again after reinclude.
Please check the settings (parameters) - hers can be a big delta for reporting (standard 1 degree). You could change it for a reporting time frame - but remember about battery...
A good idea is to modify the LED "light show" - if you want to save battery. I have switched it off - do not need it at every place ;)
Posted: Friday 28 November 2014 22:24
by nay
I found for reliable operation you need the FGMS001 to have version 2.6 of the firmware otherwise temp/lux does not report reliably.
Posted: Wednesday 10 December 2014 21:17
by booster
I was thinking about buying the FGMS001, but accurate temp/lux is important....
If I get one with an older firmware, can this be updated?
Posted: Tuesday 30 December 2014 5:11
by elgarne
In my case, I have two FGMS001 and see both of them as a Sensor of type Lightning 2, cf. attached image.
In the logs, I see
2014-12-30 05:00:05 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: SENSOR BINARY, Label: Sensor, Instance: 0
2014-12-30 05:00:05 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SENSOR BINARY, Label: Sensor, Instance: 0
Any idea how I can fix that?
Thanks.
Posted: Tuesday 30 December 2014 22:32
by JDD
Hello
I have also the same problem, but with the Lux.
This information is not showed in domoticz, but I can see it in the zwave me interface.
I run an instance of Jeedom for test and it has the lux from the same zwaveme.
And zaweme tells me that the firmware is 2.6
Any idea?
Posted: Friday 22 January 2016 20:28
by Scones
Hi folks,
I'm in the same boat. It took me ages to get the Fibaro to appear at all.
I now have the sensor appearing as a node in setup->Hardware->Z-Wave USB -> Setup.
If I click on the Fibaro sensor node, I see all of the settings, including PIR, tamper, and temperature.
In Setup->Devices I have two sensors, one being the motion sensor and I think the other being the tamper. However, I cannot get a temperature sensor in Domoticz
I have tried adjusting the values to make the sensor report the LUX and temperature more often.
Any suggestions on what to try next?
Posted: Wednesday 27 January 2016 16:14
by Scones
Adding this here to help people in future. As I've put elsewhere on the forum, I managed to fix this by going into Setup->Hardware->USB Z-Wave->Setup and edited the Fibaro node settings.
Once I'd updated the node settings to report temperature and LUX levels, it was a case of waiting a while and then Domoticz created the devices as required.
Posted: Thursday 22 August 2019 10:48
by gomsoo
I have actually the same issue.
I had hard reset my usb-zwave stick, reinclude each device, which works fine.
But my Fibaro Eye (Motion Sensor) isn't listet in my device list (for all my 3 eyes).
Before the resetting , I hadn't any issues about that.
I'm exclude, include the device, reboot the systems multiple times, set and change the configuration in the nodes (that works).
Any other suggestions on that topic?
Domoticz Version: 4.10826
