Shelly Plug-S unused switch device discovered
Posted: Tuesday 25 April 2023 17:56
by Solderbro
Domoticz stable with mosquitto and shelly-MQTT addon from github on debian buster.
Bought and added 2 shelly plug-s from cloud to MQTT. Both of them gave 4 devices, where the a unusable switch appears, does anyone have an idea for what the second switch exist?
2564 Shelly shellyplug-s-temp 8 MESSP Temperatur Temp LaCrosse TX3 27.9 C - -
2563 Shelly shellyplug-s 7 MESSP Switch Light/Switch Switch On - -
2562 Shelly shellyplug-s-energy 6 MESSP KWh General kWh 0.019 kWh - -
2561 Shelly shellyplug-s-online 5 MESSP Dummy Light/Switch Switch On - -
Are there devices missing, for example volts?
Solderbro
Re: Shelly Plug-S unused switch device discovered
Posted: Sunday 09 July 2023 9:46
by lwolf
Solderbro wrote: Tuesday 25 April 2023 17:56 Domoticz stable with mosquitto and shelly-MQTT addon from github on debian buster.
Solderbro
I see energy, but not seeing power dev, its maybe not yet sent by the device, or simply not enabled on the hardware page:
https://github.com/enesbcs/Shelly_MQTT/ ... working%3F
Volts are not provided by the firmware, so it is not missing:
https://shelly-api-docs.shelly.cloud/ge ... plugs-mqtt
Online message sent by the device when it comes online... its not a switch its a binary input. You can disable it safely.
