[SOLVED] TuYa TS0041 momentary switch via Zigbee2MQTTAutodiscover
Posted: Monday 24 April 2023 13:09
I have a TuYa TS0041 momentary switch.
This switch generates 3 devices in Domoticz that get triggered based on the ' type' of buttonpress: single, double or hold.
The Zigbee2MQTT part and the integration with Domotiocz seem to be OK....
The trouble I seem to have is that the 'on' on the Domoticz switch is within the second overwritten by the following 'off' .
The result of which is:
Not sure if the behaviour of my TS0041 is different from other momentary switches (Eg TuYa TS0001 or Sonoff SNZB-01)
Should I adapt (is that possible??) the configuration of the switch in Zigbee2MQTT to make sure the 'on' lasts longer than 1 second?
- I only see 'off' in the log.
My events do not seem to trigger either.
