Open Meteo Weather Service
FireWizard
Post by FireWizard »
As Darksky, thanks to Apple, stopped its service by April 1st, I have been seriously looking for an alternative.
I knew that a PR for Visual Crossing had been posted on Github as a replacement for Darksky weather, but decided to look further in order to minimize the risk that this service would closed down as well in the future or that it would turn into a paid service.
I looked to various services and finally selected Open Meteo. See: https://open-meteo.com/
Advantages
1. Open Source.
2. No API key needed
3. Multiple Data Sources.
4. Free for non-commercial use.
5. Data limit 10.000 calls/day
6, Configurable http request to receive dedicated response.
7. No plug-ins or scripts in Domoticz. Just free configuration of virtual sensors in Node-RED.
8. Large amount of data
Temp tab:
You are free to use the (virtual) sensors of your choice. In the example (Temperature tab) above I used a combined Temperature, Humidity and Barometer sensor (THB), but also individual sensor for Temperature, Humidity and Barometer. Other combinations, such as TempHum or TempBar are also possible.
Weather tab:
See the Node-RED flow below:
The upper stream requests the LAT/LON co-ordinates from Domoticz. It is initiated during start of the flow
You might want to consider it to change that and not use the location of your Home address but e.g your personal location, that you receive from your smartphone. These location is stored in 2 global variables and used in the lower stream.
The Inject node injects a command every 10 minutes but feel free to change it, as long as you stay under 10,000 calls/day.
The "Change" node sets several parameters, to be used in the HTTP requests.
The "Function" node is slightly modified, but based on the post in viewtopic.php?p=263147&hilit=weather#p263147
at 09 Dec 2020, 16:57.
I tested this flow for approx 2 weeks and no issues were discovered. So in my opinion, it is ready to share it with the community.
The complete Node-RED flow, you will find below:
        "id": "4d2122f74f3e3752",
        "type": "tab",
        "label": "Open Meteo",
        "disabled": false,
        "info": "",
        "env": []
        "id": "5c0992b908348937",
        "type": "inject",
        "z": "4d2122f74f3e3752",
        "name": "Request Home GPS",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": true,
        "onceDelay": 0.1,
        "topic": "home_GPS",
        "payload": "",
        "payloadType": "date",
        "x": 260,
        "y": 180,
        "wires": [
                "714e4cf506f868f1"
        "id": "714e4cf506f868f1",
        "type": "http request",
        "name": "HTTP Domoticz",
        "method": "GET",
        "ret": "obj",
        "paytoqs": "ignore",
        "url": "http://192.168.10.50:8080/json.htm?type=settings",
        "tls": "",
        "persist": false,
        "proxy": "",
        "insecureHTTPParser": false,
        "authType": "",
        "senderr": false,
        "headers": [],
        "x": 500,
        "y": 180,
        "wires": [
                "9fb35f4b716ee86d",
                "a61b6e9fc691a88b"
        "id": "9fb35f4b716ee86d",
        "type": "debug",
        "name": "debug 163",
        "active": false,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "payload.Location",
        "targetType": "msg",
        "statusVal": "",
        "statusType": "auto",
        "x": 710,
        "y": 140,
        "wires": []
        "id": "8ec742414f97ae75",
        "type": "comment",
        "name": "Read Lat/Lon from Domoticz",
        "info": "",
        "x": 400,
        "y": 120,
        "wires": []
        "id": "643ab3f67da319a5",
        "type": "inject",
        "name": "Inject",
        "props": [],
        "repeat": "600",
        "crontab": "",
        "once": true,
        "onceDelay": 0.1,
        "topic": "",
        "x": 230,
        "y": 280,
        "wires": [
                "458f6d595493e6f7"
        "id": "0f132cd63669ed9a",
        "name": "Request Open Meteo",
        "method": "GET",
        "ret": "obj",
        "url": "https://api.open-meteo.com/v1/forecast?latitude={{{lat}}}&longitude={{{lon}}}&current_weather={{{cw}}}&windspeed_unit={{{wind_set}}}&forecast_days={{{fc_days}}}&hourly={{{hourly}}}&daily={{{daily}}}&timezone={{{tz}}}",
        "tls": "",
        "persist": false,
        "proxy": "",
        "authType": "",
        "senderr": false,
        "headers": [],
        "x": 740,
        "y": 280,
        "wires": [
                "9bad3ec41889ed8a",
                "a7129cdafdb18bde"
        "id": "0c1dcd4e5a7b64bd",
        "type": "debug",
        "name": "debug 179",
        "active": false,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "payload",
        "statusVal": "",
        "x": 1210,
        "y": 240,
        "wires": []
        "id": "458f6d595493e6f7",
        "type": "change",
        "name": "Set Open Meteo parameters",
        "rules": [
                "t": "set",
                "p": "lat",
                "pt": "msg",
                "to": "lat",
                "tot": "flow"
                "t": "set",
                "p": "lon",
                "pt": "msg",
                "to": "lon",
                "tot": "flow"
                "t": "set",
                "p": "cw",
                "pt": "msg",
                "to": "true",
                "tot": "bool"
                "t": "set",
                "p": "hourly",
                "pt": "msg",
                "to": "temperature_2m,relativehumidity_2m,windspeed_10m,dewpoint_2m,apparent_temperature,pressure_msl,cloudcover,winddirection_10m,windgusts_10m,direct_radiation,precipitation,precipitation_probability,rain,visibility",
                "tot": "str"
                "t": "set",
                "p": "daily",
                "pt": "msg",
                "to": "uv_index_max,uv_index_clear_sky_max,winddirection_10m_dominant",
                "tot": "str"
                "t": "set",
                "p": "tz",
                "pt": "msg",
                "to": "auto",
                "tot": "str"
                "t": "set",
                "p": "fc_days",
                "pt": "msg",
                "to": "1",
                "tot": "num"
                "t": "set",
                "p": "wind_set",
                "pt": "msg",
                "to": "ms",
                "tot": "str"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 460,
        "y": 280,
        "wires": [
                "0f132cd63669ed9a"
        "id": "a61b6e9fc691a88b",
        "type": "change",
        "name": "",
        "rules": [
                "t": "set",
                "p": "lat",
                "pt": "flow",
                "to": "payload.Location.Latitude",
                "tot": "msg"
                "t": "set",
                "p": "lon",
                "pt": "flow",
                "to": "payload.Location.Longitude",
                "tot": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 720,
        "y": 180,
        "wires": [
        "id": "229d06c564f6fd56",
        "type": "comment",
        "name": "Open-Meteo",
        "info": "See: https://open-meteo.com/",
        "x": 710,
        "y": 240,
        "wires": []
        "id": "a7129cdafdb18bde",
        "type": "function",
        "name": "Prepare Domoticz",
        "func": "// This function determines the comfort level for Domoticz based on the humidity.\n\nfunction comfortlevel(hum) {\n    \nswitch (true) {\n    case hum > 70: { hum_stat = 3 } break;\n    case hum < 30: { hum_stat = 2 } break;\n    case hum >= 30 && hum <= 45: { hum_stat = 0 } break;\n    case hum > 45 && hum <= 70: { hum_stat = 1 } break;\n    default: { hum_stat = 0 } break;\n}\nreturn hum_stat;\n}\n\n// This function determines the prediction (barometer forecast) for Domoticz based on the barometer pressure.\n\nfunction bar_forecast(pres) {\n\nswitch (true) {\n    case pres > 1030: { bar_for = 1 } break;\n    case pres > 1010 && pres <= 1030: { bar_for = 2 } break;\n    case pres > 990 && pres <= 1010: { bar_for = 3 } break;\n    case pres > 970 && pres <= 990: { bar_for = 4 } break;\n    default: { bar_for = 0 } break;\n}\nreturn bar_for;\n}\n// This function determines the wind direction in abbreviated text for Domoticz based on the average bearing.\n\nfunction winddir(avgb) {\n\nswitch (true) {\n    case avgb >= 0 && avgb <= 11.25: { dir = \"N\" } break;\n    case avgb >= 11.26 && avgb <= 33.75: { dir = \"NNE\" } break;\n    case avgb >= 33.76 && avgb <= 56.25: { dir = \"NE\" } break;\n    case avgb >= 56.26 && avgb <= 78.75: { dir = \"ENE\" } break;\n    case avgb >= 78.76 && avgb <= 101.25: { dir = \"E\" } break;\n    case avgb >= 101.26 && avgb <= 123.75: { dir = \"ESE\" } break;\n    case avgb >= 123.76 && avgb <= 146.25: { dir = \"SE\" } break;\n    case avgb >= 146.26 && avgb <= 168.75: { dir = \"SSE\" } break;\n    case avgb >= 168.76 && avgb <= 191.25: { dir = \"S\" } break;\n    case avgb >= 191.26 && avgb <= 213.75: { dir = \"SSW\" } break;\n    case avgb >= 213.76 && avgb <= 236.25: { dir = \"SW\" } break;\n    case avgb >= 236.26 && avgb <= 258.75: { dir = \"WSW\" } break;\n    case avgb >= 258.76 && avgb <= 281.25: { dir = \"W\" } break;\n    case avgb >= 281.26 && avgb <= 303.75: { dir = \"WNW\" } break;\n    case avgb >= 303.76 && avgb <= 326.25: { dir = \"NW\" } break;\n    case avgb >= 326.26 && avgb <= 348.75: { dir = \"NNW\" } break;\n    case avgb >= 348.76 && avgb <= 359.99: { dir = \"N\" } break;\n    default: { dir = \"?\" } break;\n}\nreturn dir;\n}\n\nlet hrs = parseInt(msg.payload.current_weather.time.split(\"T\")[1].split(\":\")[0]);\n\nlet ba = msg.payload.hourly.pressure_msl[hrs]; //barometer pressure\nlet pr = bar_forecast(ba); // prediction (barometer forecast)\nlet tm = msg.payload.current_weather.temperature; // temperature\nlet hu = msg.payload.hourly.relativehumidity_2m[hrs]; // humidity\nlet lv = comfortlevel(hu); // comfort level\nlet rt = (msg.payload.hourly.precipitation[hrs] * 100).toFixed(); // rain rate\nlet fl = msg.payload.hourly.precipitation[hrs]; // rain fall\nlet sr = msg.payload.hourly.direct_radiation[hrs]; // solar radiation\nlet uv = msg.payload.daily.uv_index_max[0]; // UV radiation\nlet wd = msg.payload.current_weather.winddirection; // wind bearing\nlet sp = (msg.payload.current_weather.windspeed * 10).toFixed(1); // wind speed in 0.1 m/s\nlet gu = (msg.payload.hourly.windgusts_10m[hrs] * 10).toFixed(1); // wind gust in 0.1 m/s\nlet ch = msg.payload.hourly.apparent_temperature[hrs]; // chill temperature\nlet avgbr = msg.payload.daily.winddirection_10m_dominant[0]; // average daily dominant bearing\n//let dr = winddir(avgbr); // dominant average daily wind direction in abbreviated text; Alternative, to be used instead of wd\nlet dr = winddir(wd); // wind direction in abbreviated text; Alternative, to be used instead of avgbr\n//let txt = msg.payload.forecast; // weather forecast text, if available\nlet dp = msg.payload.hourly.dewpoint_2m[hrs]; // dew point\nlet vis = msg.payload.hourly.visibility[hrs]/1000;\nlet cc = msg.payload.hourly.cloudcover[hrs];\n\nlet msg1 = {};\nlet msg2 = {};\nlet msg3 = {};\nlet msg4 = {};\nlet msg5 = {};\nlet msg6 = {};\nlet msg7 = {};\nlet msg8 = {};\nlet msg9 = {};\nlet msg10 = {};\nlet msg11 = {};\nlet msg12 = {};\nlet msg13 = {};\nlet msg14 = {};\nlet msg15 = {};\n\nmsg1.payload = {\"command\":\"udevice\", \"idx\":20, \"svalue\":tm.toString()}; // To be used for Temperature sensor\nmsg2.payload = {\"command\":\"udevice\", \"idx\":21, \"nvalue\":hu, \"svalue\":lv.toString()}; // To be used for Humidity sensor\nmsg3.payload = {\"command\":\"udevice\", \"idx\":22, \"svalue\":ba.toString() + \";\" + pr.toString()}; // To be used for Barometer sensor\n//msg4.payload = {\"command\":\"udevice\", \"idx\":33, \"svalue\":tm.toString() + \";\" + hu.toString() + \";\" + lv.toString()}; // To be used for Temperature + Humidity sensor\nmsg5.payload = {\"command\":\"udevice\", \"idx\":11, \"svalue\":tm.toString() + \";\" + hu.toString() + \";\" + lv.toString() + \";\" + ba.toString() + \";\" + pr.toString()}; // To be used for Temperature + Humidity + Barometer sensor\n//msg6.payload = {\"command\":\"udevice\", \"idx\":35, \"svalue\":tm.toString() + \";\" + ba.toString() + \";\" + pr.toString()}; // To be used for Temperature + Barometer sensor\nmsg7.payload = {\"command\":\"udevice\", \"idx\":14, \"svalue\":rt.toString() + \";\" + fl.toString()}; // To be used for Rain sensor\nmsg8.payload = {\"command\":\"udevice\", \"idx\":12, \"svalue\":wd.toString() + \";\" + dr.toString() + \";\" + sp.toString() + \";\" + gu.toString() + \";\" + tm.toString() + \";\" + ch.toString()}; // To be used for Wind sensor\n//msg9.payload = {\"command\":\"udevice\", \"idx\":38, \"svalue\":wd.toString() + \";\" + dr.toString() + \";\" + sp.toString() + \";\" + gu.toString() + \";\" + tm.toString() + \";\" + ch.toString()}; // To be used for Wind + Temperature + Chill sensor\nmsg10.payload = {\"command\":\"udevice\", \"idx\":13, \"svalue\":uv.toString() + \";\" + \"0\"}; // To be used for UV sensor\nmsg11.payload = {\"command\":\"udevice\", \"idx\":17, \"svalue\":sr.toString()}; // To be used for Solar radiation sensor\n//msg12.payload = {\"command\":\"udevice\", \"idx\":41, \"svalue\":\"txt\"}; // To be used for Text sensor, if short weather text is available\nmsg13.payload = {\"command\":\"udevice\", \"idx\":18, \"svalue\":dp.toString()}; // To be used for  Dewpoint temperature sensor\nmsg14.payload = {\"command\":\"udevice\", \"idx\": 15, \"svalue\": vis.toString()}; // To be used for Visibility sensor\nmsg15.payload = {\"command\":\"udevice\", \"idx\": 16, \"svalue\": cc.toString()}; // To be used for Cloud Cover sensor\n\n//return [[msg1,msg2,msg3,msg4,msg5,msg6,msg7,msg8,msg9,msg10,msg11,msg12,msg13,msg14],msg15];\nreturn [[msg1,msg2,msg3,msg5,msg7,msg8,msg10,msg11,msg13,msg14,msg15]]\n",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 990,
        "y": 280,
        "wires": [
                "0c1dcd4e5a7b64bd",
                "cd4943f82070c026"
        "id": "9bad3ec41889ed8a",
        "type": "debug",
        "name": "debug 180",
        "active": false,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "false",
        "statusVal": "",
        "x": 970,
        "y": 240,
        "wires": []
        "id": "cd4943f82070c026",
        "type": "mqtt out",
        "name": "To Domoticz",
        "topic": "domoticz/in",
        "qos": "0",
        "retain": "false",
        "respTopic": "",
        "contentType": "",
        "userProps": "",
        "correl": "",
        "expiry": "",
        "broker": "108bbff65a6cdbf3",
        "x": 1210,
        "y": 280,
        "wires": []
        "id": "108bbff65a6cdbf3",
        "type": "mqtt-broker",
        "name": "",
        "broker": "192.168.10.51",
        "port": "1883",
        "clientid": "",
        "autoConnect": true,
        "usetls": false,
        "protocolVersion": "4",
        "keepalive": "60",
        "cleansession": true,
        "birthTopic": "",
        "birthQos": "0",
        "birthPayload": "",
        "birthMsg": {},
        "closeTopic": "",
        "closeQos": "0",
        "closePayload": "",
        "closeMsg": {},
        "willTopic": "",
        "willQos": "0",
        "willPayload": "",
        "willMsg": {},
        "userProps": "",
        "sessionExpiry": ""
Do not forget to insert your own IDX numbers and the configuration of your MQTT server.
In case of questions, do not hesitate to ask.
Last edited by FireWizard on Saturday 05 August 2023 19:20, edited 2 times in total.
EdwinK
Re: Open Meteo Weather Service
Post by EdwinK »
Thanks. Got it working. Even for a Node-Red n00b like myself this was pretty easy to do.
What is wrong with the Meteorologisk institutt Norway (No API key needed) weather integration?
See also https://www.domoticz.com/wiki/Weather
EdwinK
Post by EdwinK »
Just need to find the Lux
edit: It seems to be there, as I now suddenly have LUX.
Toulon7559
Domoticz version: <2025
Post by Toulon7559 »
Open_Meteo really seems a gem with high resolution and lots of background-data due to the multiple sources.
That service also provides solution to fill-in the Ozone-VirtualDevice left vacant by the exit of DarkSky, and many other gas-related, surface-oriented indicators.
@waltervi cs
MeteoInstitutt Norway is good and existing alternative in Domoticz, very easy to activate without any script.
As indicated in other thread, the wind-information is available in the download,
but in present implementation of Domoticz the related virtual device is absent, and needs to be added for complete package.
Another small 'problem' is that after activation under 'Hardware' the devices are slowly appearing under 'Devices'.
In other words: the implementation in Domoticz might be improved .......
FireWizard
Hello @waltervl,
The fact that I share another weather solution with the community, does not mean that there is something wrong with MET.no or any other weather service and with its integration in Domoticz. This gives people the possibility to choose and I found that the API of this Open Meteo was easy to customize.
This weather service uses 7 data sources and among them MET Nordic. So it definitively uses the data from met.no.
It says:
The API makes use of MET Nordic weather models exclusively for North Europe, offering exceptional short-term weather forecasts with hourly updates and 1 km resolution. However, for longer forecasts of up to 16 days, the generic Weather Forecast API transparently combines MET Nordic with other weather models to take advantage of hourly updates.
And also Met says: The data is mainly for Norway or Scandinavia, except Locationforecast (and Frost).
This service delivers a full weather forecast for one location, that is, a forecast with several parameters for a nine-day period.
The accuracy and update speed is the best for Scandinavian countries, but is less for other locations in the world.
Last edited by FireWizard on Saturday 05 August 2023 19:25, edited 2 times in total.
FireWizard
Hello @EdwinK,
Where did you find that and from what light source do you expect the lux?
I don't think this has something to do with the weather.
Do you mean visibility?
That is available?
EdwinK
Post by EdwinK »
I really don't know where it came from. I removed all the other weather plugins I had, then in the dummy I created for this Weather then created a LUX sensor, and it was filled with info. It's not the visibility thing. Since it hasn't updated it self, I guess it might be some leftover stuff from an older script.
FireWizard
Hello @EdwinK,
I think so, as well, because Lux data is not available.
EdwinK
Post by EdwinK »
Had it running for some time, but now i notice that it didn't update for some 9 days or so. Checking the flow, I see this in debug of node: Prepare Domoticz 'TypeError: Cannot read property 'time' of undefined'.
Around that time I changed the request to http://192.168.0.11:8080/json.htm?type= ... getdevices to follow the changes in Domoticz. (http, because I have no clue on how to get the secure part on a local machine.
FireWizard
Hello @EdwinK,
It was a good idea to update the JSON request to Domoticz. However the old command still works, but will be deprecated sooner or later.
The reason you get that error message is, that the changed command is wrong. The upper stream grabs the lat/lon, as in the Domoticz settings and stores it in two flow variables. Both variables are used in the HTTP request to OpenMeteo. If this data is missing you get that error message.
The old command to retrieve these setting was:
You changed that to:
http://192.168.0.11:8080/json.htm?type=command&param=getdevices
This is wrong and should be:
http://192.168.0.11:8080/json.htm?type=command&param=getsettings
So getsettings instead of getdevices.
Try this and it will work again.
EdwinK
Post by EdwinK »
Ah... Thanks. Don't know what I was doing then, besides making the error.
