Unable to access Domoticz from another pc
Piet47
Domoticz version: 2022.3
Post by Piet47 »
High, I run Domoticz on a windows 10 prof machine, The update from the Smart meters are registrated and visable on that machine.
Any other pc that tries to access get the message "unable to reach the site".
Can somebody help me to solve this problem/
kiddigital
Re: Unable to access Domoticz from another pc
Post by kiddigital »
You should be able to access Domoticz using HTTP on port 8080 by entering the correct IP address of your Windows PC that runs Domoticz.
Or via HTTPS on port 443 (or other port if configured).
Does the Windows PC have an internal firewall maybe? Check Windows Defender (I think it is called that on Win10).
habahabahaba
Domoticz version: 2024.4
Post by habahabahaba »
Computers in same sub-net?
May be you had to add port redirection in router?
Antiviruses? Firewalls?
1000 cases may be
Piet47
Post by Piet47 »
Hi, I don't quite understand what is happening. The strange thing is that data from the smart meter just comes through on the same IP address and port no. Also when I try to ping from any PC on the network I get a timeout.
kiddigital
If you can provide more details, maybe we can help.
- what is the IP address of the machine that runs Domoticz
- what is the address of the machine you use to access Domoticz. What Browser are you using
- what is the URL you use in the Browser when trying to connect to Domoticz
And maybe some more info like the Domoticz version, etc.
