solaredge on domoticz slave
Posted: Friday 21 April 2023 22:06
by tiga
i have installed solaredge modbus on a slave raspberry.
but the devices do not appear on the master raspberry.
i have a p1 working perfect between the 2.
making a new dummy switch on the slave appears on the master.
how to get this working?
Re: solaredge on domoticz slave
Posted: Friday 21 April 2023 22:28
Master/slave is not working for python plugin managed devices.
It is a known issue.
Posted: Friday 21 April 2023 22:46
by tiga
ok thank you.
i will see to make a work around.
Posted: Sunday 23 April 2023 12:49
by Kedi
"Best" workaround is via NodeRed.
Posted: Sunday 23 April 2023 21:53
by tiga
strangely i can not get any dummy switch to my master domoticz.
text device....not appearing on master
custom electric device..... not appearing on master....
dummy on/off switch is appearing on master(just for testing purpous)
i just want to get 2 numbers from the slave to my master.....i dont know how(want to) to setup nodered.
there must be an easy way
Posted: Friday 28 April 2023 14:42
by tiga
Anyone with a simple solution to get the 2 values from the slave to the master?
Or is node red my only option?
Posted: Friday 28 April 2023 23:48
by tiga
ok after a "little" research node red seems to be the way to go.
does anyone have a good link for a page to get this started up?
this is totally new for me
Posted: Saturday 29 April 2023 11:35
by sincze
If possible run the whole mosquitto and node-red in a nice docker environment.
https://contactkring.nl/phpbb/viewtopic.php?t=744
Will get you going.
