Serial port open detection
Posted: Thursday 20 April 2023 21:13
I'm just gonna throw this out there and see what happens. I'm trying to fix a long term ongoing issue with the RS485 Modbus RTU plugin that uses minimalmodbus viewtopic.php?t=21297. In Domoticz 2023.1 the plugsin are loaded very fast one after another and plugsin that talk to serial bus get stuck straight away if the plugsin executions aren't space apart in time due to the fact that the port is already open.
I'm rubbish at Python but I'll have a go as no one else has managed to come up with a better solution yet.
How can I check if the serial port is already open in the following example taken from https://github.com/remcovanvugt/SDM120M ... icz-plugin
My idea is to check if the port is open, if it isn't then use the onHeartBeat to try the plugin again after say 10 intervals. This would be a much better fix than my editing Plugins.cpp to insert a 1 second delay when initially loading the plugsin in, in the first place.
I've contacted the plugin author and no joy, its not being maintained.
#!/usr/bin/env python
Eastron SDM120-Modbus Smart Meter Single Phase Electrical System. The Python plugin for Domoticz
Original author: MFxMF and bbossink
Modified by: remcovanvugt
Requirements:
1.python module minimalmodbus -> http://minimalmodbus.readthedocs.io/en/master/
(pi@raspberrypi:~$ sudo pip3 install minimalmodbus)
2.Communication module Modbus USB to RS485 converter module
<plugin key="SDM120M" name="SDM120M Modbus" version="1.0.0" author="remcovanvugt">
<params>
<param field="SerialPort" label="Modbus Port" width="200px" required="true" default="/dev/ttyUSB0" />
<param field="Mode1" label="Baud rate" width="40px" required="true" default="9600" />
<param field="Mode2" label="Device ID" width="40px" required="true" default="1" />
<param field="Mode3" label="Reading Interval min." width="40px" required="true" default="1" />
<param field="Mode6" label="Debug" width="75px">
<options>
<option label="True" value="Debug"/>
<option label="False" value="Normal" default="true" />
</options>
</param>
</params>
</plugin>
import minimalmodbus
import serial
import Domoticz
minimalmodbus.CLOSE_PORT_AFTER_EACH_CALL=True
class BasePlugin:
def __init__(self):
self.runInterval = 1
self.rs485 = ""
return
def onStart(self):
self.rs485 = minimalmodbus.Instrument(Parameters["SerialPort"], int(Parameters["Mode2"]))
self.rs485.serial.baudrate = Parameters["Mode1"]
self.rs485.serial.bytesize = 8
self.rs485.serial.parity = minimalmodbus.serial.PARITY_NONE
self.rs485.serial.stopbits = 1
self.rs485.serial.timeout = 1
self.rs485.debug = False
self.rs485.mode = minimalmodbus.MODE_RTU
devicecreated = []
Domoticz.Log("SDM120M Modbus plugin start")
self.runInterval = int(Parameters["Mode3"]) * 1
if 1 not in Devices:
Domoticz.Device(Name="Total System Power", Unit=1,TypeName="Usage",Used=0).Create()
Options = { "Custom" : "1;VA"}
if 2 not in Devices:
Domoticz.Device(Name="Import Wh", Unit=2,Type=243,Subtype=29,Used=0).Create()
Options = { "Custom" : "1;kVArh"}
if 3 not in Devices:
Domoticz.Device(Name="Export Wh", Unit=3,Type=243,Subtype=29,Used=0).Create()
if 4 not in Devices:
Domoticz.Device(Name="Total kWh", Unit=4,Type=243,Subtype=29,Used=0).Create()
if 5 not in Devices:
Domoticz.Device(Name="Voltage", Unit=5,Type=243,Subtype=8,Used=0).Create()
Options = { "Custom" : "1;V"}
if 6 not in Devices:
Domoticz.Device(Name="Import power", Unit=6,TypeName="Usage",Used=0).Create()
if 7 not in Devices:
Domoticz.Device(Name="Export power", Unit=7,TypeName="Usage",Used=0).Create()
def onStop(self):
Domoticz.Log("SDM120M Modbus plugin stop")
def onHeartbeat(self):
self.runInterval -=1;
if self.runInterval <= 0:
# Get data from SDM120
Total_System_Power = self.rs485.read_float(12, functioncode=4, numberOfRegisters=2)
Import_Wh = self.rs485.read_float(72, functioncode=4, numberOfRegisters=2)
Export_Wh = self.rs485.read_float(74, functioncode=4, numberOfRegisters=2)
Total_kwh = self.rs485.read_float(342, functioncode=4, numberOfRegisters=2)
Voltage = self.rs485.read_float(0, functioncode=4, numberOfRegisters=2)
Import_power = self.rs485.read_float(88, functioncode=4, numberOfRegisters=2)
Export_power = self.rs485.read_float(92, functioncode=4, numberOfRegisters=2)
#Devices[4].Update(0,str(Current_L1)+";"+str(Current_L2)+";"+str(Current_L3))
#Update devices
Devices[1].Update(0,str(Total_System_Power))
Devices[2].Update(0,str(Total_System_Power)+";"+str(Import_Wh*1000))
Devices[3].Update(0,str(Export_Wh))
Devices[4].Update(0,str(Total_kwh))
Devices[5].Update(0,str(Voltage))
Devices[6].Update(0,str(Import_power))
Devices[7].Update(0,str(Export_power))
if Parameters["Mode6"] == 'Debug':
Domoticz.Log("SDM120M Modbus Data")
Domoticz.Log('Total system power: {0:.3f} W'.format(Total_System_Power))
Domoticz.Log('Import Wh: {0:.3f} kWh'.format(Import_Wh))
Domoticz.Log('Export Wh: {0:.3f} kWh'.format(Export_Wh))
Domoticz.Log('Total kwh: {0:.3f} kWh'.format(Total_kwh))
Domoticz.Log('Voltage: {0:.3f} V'.format(Voltage))
Domoticz.Log('Import power: {0:.3f} W'.format(Import_power))
Domoticz.Log('Export power: {0:.3f} W'.format(Export_power))
self.runInterval = int(Parameters["Mode3"]) * 6
global _plugin
_plugin = BasePlugin()
def onStart():
global _plugin
_plugin.onStart()
def onStop():
global _plugin
_plugin.onStop()
def onHeartbeat():
global _plugin
_plugin.onHeartbeat()
# Generic helper functions
def DumpConfigToLog():
for x in Parameters:
if Parameters[x] != "":
Domoticz.Debug("'" + x + "':'" + str(Parameters[x]) + "'")
Domoticz.Debug("Device count: " + str(len(Devices)))
for x in Devices:
Domoticz.Debug("Device: " + str(x) + " - " + str(Devices[x]))
Domoticz.Debug("Device ID: '" + str(Devices[x].ID) + "'")
Domoticz.Debug("Device Name: '" + Devices[x].Name + "'")
Domoticz.Debug("Device nValue: " + str(Devices[x].nValue))
Domoticz.Debug("Device sValue: '" + Devices[x].sValue + "'")
Domoticz.Debug("Device LastLevel: " + str(Devices[x].LastLevel))
return
