Device refused to go OFF after motion Topic is solved
BarryT
Domoticz version: 2024.3
Post by BarryT »
i have several motion detectors in my house wich are turning on lights, what is working perfectly well in a lua script,
but 1 device refused to go OFF after x seconds no motion detected.
Turning ON device works, like all other do:
Trigger=DEVICE:
if devicechanged['Zigbee - BewegingBadkamer'] == 'On'
then
    commandArray[#commandArray+1] = {['LampBadkamer'] ='Set Level 70' }
    commandArray[#commandArray+1] = {['LampBadkamer'] ='Set Level 70 AFTER 1' }
    print('Verlichting Badkamer AAN')
Turning OFF the device does not work at all, also it looks like the scipt does not excluded at all (as nothing see in the log).
Trigger=TIME:
function datetimedifferencenow(s)
             s = s .. ":00"
             year = string.sub(s, 1, 4)
             month = string.sub(s, 6, 7)
             day = string.sub(s, 9, 10)
             hour = string.sub(s, 12, 13)
             t1 = os.time()
             t2 = os.time{year = year, month = month, day = day, hour = hour, min = minutes, sec = seconds}
             difference = os.difftime(t1, t2)
             return difference
if otherdevices['Zigbee - BewegingBadkamer'] == 'Off' and datetimedifferencenow(otherdevices_lastupdate['Zigbee - BewegingBadkamer']) >= 240 and datetimedifferencenow(otherdevices_lastupdate['Zigbee - BewegingBadkamer']) <= 300
then
    commandArray[#commandArray+1] = {['LampBadkamer'] ='Off'}
    commandArray[#commandArray+1] = {['LampBadkamer'] ='Off AFTER 1'}
    print('Verlichting Badkamer UIT')
Someone knows whats going on in here?
Also tried to make a new script and also with a new name, and tried a remote switch as well, but nothing worked.
All other scripts and lights/motions are working perfectly with exactly the same scripts.
The motion is sending out the ON/OFF state correctly, and light goes ON correctly, but it does never turning OFF..
BarryT
Re: Device refused to go OFF after motion
Post by BarryT »
Last update: On remote site with exactly the same script it works.....
I'm lost! :roll:
BarryT
Post by BarryT »
Update:
I removed the (zigbee) motion sensor from domoticz and added it again, after that it works again.
It was a weird one, but it's fixed for now so this case can be closed... :)
