Neo siren pairing issue
Posted: Tuesday 18 April 2023 22:05
I have a Neo Siren (Zigbee ID _TZE204_t1blo2bj listed as supported on blakadder), but I am not able to pair it.
Plugin version: 6.3.012
Domoticz: 2023.1 (build 15178)
Coordinator: Sonoff USB dongle plus (CC2652P), Firmware: Znp - Z-Stack 3.30+ (build 20221226)
This is what I get in the logs when trying to pair it:
I have 48 other objects (10 routers, 38 sensors) from different vendors (Xiaomi, Aqara, Philips, Ikea, Heiman, Legrand) in my network, all working properly.
What could be the issue with the siren?
I can provide additional logs if needed.
Thank you.
Apr 17 22:08:00 rasp3 domoticz: Zigate: Accepting new Hardware: Enable (On)
Apr 17 22:08:20 rasp3 domoticz: Zigate: [None] NEW OBJECT: 80e4 None
Apr 17 22:08:20 rasp3 domoticz: Zigate: [-] NEW OBJECT: 80e4 Active Endpoint Response Ep: 01 LQI: 0
Apr 17 22:08:20 rasp3 domoticz: Zigate: [-] NEW OBJECT: 80e4 Active Endpoint Response Ep: f2 LQI: 0
Apr 17 22:08:25 rasp3 domoticz: Zigate: [0] NEW OBJECT: 80e4 Model Name: TS0601
Apr 17 22:08:25 rasp3 domoticz: Zigate: [0] NEW OBJECT: 80e4 Manufacturer Name: _TZE204_t1blo2bj
Apr 17 22:08:30 rasp3 domoticz: Zigate: [1] NEW OBJECT: 80e4 Model Name: TS0601
Apr 17 22:08:30 rasp3 domoticz: Zigate: [1] NEW OBJECT: 80e4 Manufacturer Name: _TZE204_t1blo2bj
Apr 17 22:08:35 rasp3 domoticz: Zigate: [2] NEW OBJECT: 80e4 Model Name: TS0601
Apr 17 22:08:35 rasp3 domoticz: Zigate: [2] NEW OBJECT: 80e4 Manufacturer Name: _TZE204_t1blo2bj
Apr 17 22:08:40 rasp3 domoticz: Zigate: [3] NEW OBJECT: 80e4 Model Name: TS0601
Apr 17 22:08:40 rasp3 domoticz: Zigate: [3] NEW OBJECT: 80e4 Manufacturer Name: _TZE204_t1blo2bj
Apr 17 22:08:45 rasp3 domoticz: Zigate: [4] NEW OBJECT: 80e4 Model Name: TS0601
Apr 17 22:08:45 rasp3 domoticz: Zigate: [4] NEW OBJECT: 80e4 Manufacturer Name: _TZE204_t1blo2bj
Apr 17 22:08:50 rasp3 domoticz: Zigate: [5] NEW OBJECT: 80e4 Model Name: TS0601
Apr 17 22:08:50 rasp3 domoticz: Zigate: [5] NEW OBJECT: 80e4 Manufacturer Name: _TZE204_t1blo2bj
Apr 17 22:08:55 rasp3 domoticz: Zigate: [6] NEW OBJECT: 80e4 Not able to get all needed attributes on time
Apr 17 22:08:55 rasp3 domoticz: Zigate: processNotinDB - not able to find response from 80e4 stop process at 0043
Apr 17 22:08:55 rasp3 domoticz: Zigate: processNotinDB - Collected Infos are : {'Version': '3', 'ZDeviceName': '', 'Status': 'UNKNOW', 'SQN': '6f', 'Ep': {'01': {'0000': {'0004': '_TZE204_t1blo2bj', '0000': '3', '0001': '74', '0005': 'TS0601', '0007': '1', 'fffe': '0', 'ffe2': '56', 'ffe4': '0', 'ffdf': '\x7f+f\x7f+\x12'}}, 'f2': {}}, 'Heartbeat': '1', 'RIA': '6', 'LQI': 80, 'Battery': {}, 'Model': 'TS0601', 'ForceAckCommands': [], 'MacCapa': '8e', 'IEEE': 'a4c1382c4e2f6a67', 'Type': {}, 'ProfileID': {}, 'ZDeviceID': {}, 'App Version': '74', 'Attributes List': {}, 'DeviceType': 'FFD', 'HW Version': '', 'Last Cmds': [], 'LogicalType': 'Router', 'Manufacturer': '', 'Manufacturer Name': '_TZE204_t1blo2bj', 'NbEp': '2', 'PowerSource': 'Main', 'ReadAttributes': {'Ep': {'01': {'0000': {'TimeStamp': 1681762113, 'iSQN': {'0004': '00', '0000': '00', '0001': '00', '0005': '00', '0007': '00', 'fffe': '00'}, 'Attributes': {'0004': '00', '0000': '00', '0001': '00', '0005': '00', '0007': '00', 'fffe': '00', 'ffe2': '00', 'ffe4': '00', 'ffdf': '00'}, 'ZigateRequest': {}}}}}, 'ReceiveOnIdle': '', 'Stack Version': '', 'Stamp': {'time': 1681762113.4834332, 'Time': '2023-04-17 22:08:33', 'MsgType': '8011', 'LastSeen': 1681762113}, 'ZCL Version': '3', 'Health': 'Live', 'Capability': ['Full-Function Device', 'Main Powered', 'Receiver during Idle', 'Standard security', 'NwkAddr should be allocated'], 'ZCLSQN': '00', 'ZDPSQN': '01', 'RollingLQI': [80, 80, 80, 76, 76, 76, 76, 76, 76, 80, 80], 'WriteAttributes': {'Ep': {'01': {'0000': {'TimeStamp': 0, 'iSQN': {}, 'Attributes': {}, 'ZigateRequest': {}}}}}, 'Epv2': {'01': {'ClusterIn': {}, 'ClusterOut': {}, 'ProfileID': {}, 'ZDeviceID': {}}, 'f2': {'ClusterIn': {}, 'ClusterOut': {}, 'ProfileID': {}, 'ZDeviceID': {}}}, 'ZCL-IN-SQN': {'ef00': '68', '000a': '69', '0000': '6f'}, 'SQN_000a': '69', 'PairingInProgress': True, 'ConsistencyCheck': 'Bad Pairing'}
Apr 17 22:08:55 rasp3 domoticz: Zigate: [6] NEW OBJECT: 80e4 Model Name: TS0601
Apr 17 22:08:55 rasp3 domoticz: Zigate: [6] NEW OBJECT: 80e4 Manufacturer Name: _TZE204_t1blo2bj
Thank you.
