Domoticz won't install on RPi
Posted: Friday 07 April 2023 12:46
Hello, dear forum readers, I just installed Raspbian on my RPi and tried to install Domoticz on top of that. It won't:
After waiting for a while I press Enter and my prompt reapears. Restarting the command gives me exactly the same result.
My specs:
Thanks in advance for any help,
Steijn van Essen
From i8088 to i7-980X in 25 years and still waiting …
But not for much longer: when Windows is gone, Intel will be next (in favor of ARM on Raspberry Pi).
pi@Domotix2:/etc$ sudo bash -c "$(curl -sSfL https://install.domoticz.com)"
::: You are root.
::: Verifying free disk space...
::: apt-get update has not been run today. Running now... done!
::: Checking apt-get for upgraded packages.... done!
::: Your system is up to date! Continuing with Domoticz installation...
::: Checking for apt-utils... installed!
::: Checking for whiptail... installed!
::: Checking for git...pi@Domotix2:/etc$My specs:
- - HW = RPi 2 Model B rev1<dot>1 (with 1 GB of RAM)
- OS = RasPi OS Buster Lite 2021-03-04 [ArmHF/32 bit] (so no graphical desktop installed)
- - I see on the domoticz<dot>com mainpage that "Arm 32bit (Raspberry/Cubie/...) 2023<dot>1<dot>15091 dated 2023-02-14" is current(?!)
- I used raspi-config to do a basic setup; left most hardware options untouched; reduced GPU RAM to 16 MB (no plans for graph desktop)
- I configured a static IP address
- I have read post # 227769 on this forum for starts
- This post more or less describes my problem, but I get a bit confused with all the tips and questions and it's from Nov 2019 ...
- I wonder why I get the message "apt-get update has not been run today. Running now... done!" again when I restart the installation.
- "apt-get-update" runs for about 8 secs and finishes with "done!"
- The next step (checking for upgraded packages) takes about 3 seconds, also ending with "done!"
- Checking for git runs for 3 seconds and then the command prompt reapears (at the end of the current message, as you can see)
- Since I was not sure it actually was my normal prompt I waited for 20 more seconds. When I then hit Enter I get my prompt on a new line. So it was my normal prompt after all ...
Steijn van Essen
