Restore from 2020.2 (on DS215+) to 2023.1 (on DS718+) : Error opening serial port !
Posted: Wednesday 22 March 2023 15:36
by boggiz
Hello, when I restore my DB on my new NAS DS718+ I have this error: 'Error sending switch command, check device/hardware (idx=nnn) !' may be the 'Error opening serial port is the cause'. But why ? /dev/ttyUSB0 is done for the RFXcom. Thank's for your help
Re: Restore from 2020.2 (on DS215+) to 2023.1 (on DS718+) : Error opening serial port !
Posted: Wednesday 22 March 2023 16:28
by waltervl
Did you set the USB device correctly in menu Setup - Hardware - RFLink?
It probably changed name when using another Synology.
Is the USB driver working on your new Synology?
Posted: Wednesday 22 March 2023 17:27
by boggiz
Yes, for me RFXtrx433XL is correctly set :
- Vue 1.jpg (43.86 KiB) Viewed 1354 times
and USB is activated at reboot by a scheduler task.
Posted: Wednesday 22 March 2023 18:25
by waltervl
So when do you get this error? What device is IDX=nnn? Is it related to Rfxcom?
Posted: Wednesday 22 March 2023 18:51
by boggiz
Errors from Lamps & Switches (RFXcom)
- Vue 2.jpg (116.02 KiB) Viewed 1348 times
No update for these devices (Water meter X10 RFXcom)
- Vue 3.jpg (70.42 KiB) Viewed 1348 times
View log with errors serial port and JSON
- Vue 4.jpg (330.95 KiB) Viewed 1348 times
Posted: Wednesday 22 March 2023 23:49
by waltervl
Yes there seems to be a communication error with your USB device. I am not familiar with Synology but it seems that on newer Linux environments you have usb devices by IDwhat do you see when you open the Port pull down list from the hardware setting? Do you see more USB devices next to ttyUSB0?
The Dzvents error can be solved by setting your security settings correctly, especially trusted networks and switch on basic auth over http.
https://www.domoticz.com/wiki/Security
Posted: Thursday 23 March 2023 12:42
by boggiz
I only saw
/dev/ttyUSB0 nothing else !
When I list tty on the 2 NAS USB was 1-1 on DS215 but 3-1 on DS718.
May be it is the problem because DS215 have only 2 usb ports while DS718 have 3.
- Vue 5 NAS DS215+.jpg (230.2 KiB) Viewed 1321 times
- Vue 6 NAS DS718+.jpg (107.98 KiB) Viewed 1321 times
Posted: Thursday 23 March 2023 15:37
by waltervl
Posted: Thursday 23 March 2023 17:49
by boggiz
Too bad the /Dev/serial/ directory is for new Linuxes but not mine.
Does this correspond to your request?
- Vue 7.jpg (52.62 KiB) Viewed 1307 times
Posted: Thursday 23 March 2023 19:25
by waltervl
I am out of options..... I hope somebody with a Synology will come by.
Posted: Thursday 23 March 2023 19:44
by PieterS
Congrats with your new Syno. I run Domoticz on a DS718 for years.
Two questions:
1: Can you tell us what version of DSM you run? 6.2 or 7.1
2: Are you running Domoticz in a Docker container?
Posted: Thursday 23 March 2023 19:55
by boggiz
@PieterS I installed the latest DSM 7.1 and yes Domoticz is under docker
Posted: Thursday 23 March 2023 20:42
by boggiz
... but on my DS215 Domoticz (jadhal) is installed on DSM 6.2.4
Posted: Thursday 23 March 2023 20:46
by PieterS
Your model was orginally delivered with DSM 6.2.. Updating to DSM 7.0 gave the "famous" problem you have.
In the WIKI of Domoticz (
https://www.domoticz.com/wiki/Synology) there is an article how to solve your problem. I suggest you should have a look there. There is a link to
https://github.com/robertklep/dsm7-usb-serial-drivers which seems hopefull to me.
As my Synology is still on 6.2 I cannot help you further on this subject. The problem you describe was the reason for me not to upgrade in the past. Maybe you can downgrade?
Good luck anyway.
Re: Restore from 2020 (on DS215+) to 2023 (on DS718+) : Error opening serial port !
Posted: Tuesday 23 May 2023 16:32
by Marathon2010
Did perform an upgrade on my DS920+ from DSM 6 to DSM 7. Faced two issues: 1) USB (for Z-wave and P1) like above not available and 2) Mosquitto not running. Implemented the solution of Bearded Thinker for USB (Search on YouTube for a video) and both are running fine now. For Mosquitto did a full remove (including data) and did a clean install of the new package. Also working fine.
Running Domiticz and Zwave-JSMQTT both under Docker.
Sneak preview:
/sbin/modprobe usbserial
/sbin/modprobe ftdi_sio
/sbin/modprobe cdc-acm
