Which upgrade path recommended from 2022-1/Buster?
Posted: Sunday 12 March 2023 12:49
Hi Forum,
After getting zwave-js-ui working to replace OZW, I have paved the way for the next upgrade steps.
I would appreciate the forum's view with respect to the optimal sequence wanting go from:
- today: 2022.1 on RPI3b Buster
- target: 2023.1 on RPI3b Bullseye
First 2022.1 -> 2022.2 -> 2023.1 then Buster -> Bullseye or another sequence? Python risks?
(Is it correct that post on 'upgrading to 2022.2 are not visible anymore and should I hence move from 2022.1 directly 2023.1?)
Best to setup username/password and trusted networks now?
I'm also reading the various related posts, but the answer might be simple..
For sure step 0 is making a backup image of the SD card
On an RPI3b Buster, I'm currently I'm using zwave-js-ui (docker compose) with MQTT AD (mosquitto) , some mod-bus devices, normal MQTT client (for Tasmota devices), Nefit EMS-ESP, Nefit Easy /Nefit server, P1 smartmeter USB, Hue, Nest (old interface), Solar Edge via WebAPI and some LUA and DzVents scripts. Running Python 2.7.16. All runs quite well as far as I can see.
