Hue Dimmer actions as separate devices
Posted: Friday 10 March 2023 17:52
I used to have the hue dimmer from Philips working as a switch with pulldown menu and a DzVents script. The device was added via the zigbee2mqtt module and the Python script.
Since the 2023.1 update I am busy migrating all my zigbee devices via the build-in zigbee2mqtt support. So far so good, but now I have separate devices (as a Push On button) for the several buttons of the Hue dimmer switch. I have tried to make it working again by changing the DzVents script but a cannot get it working. When pressed it updates with an 'Off' signal (all buttons). To check whether it is a recent Off I added lastupdate.SecondsAgo:
The lastupdate.secondsago doesn't give logical reading (after press it states >50 s as last update).
Is it possible to add the Hue dimmer as a single device with pulldown menu or does anyone know how to get this working?
devices =
'Hue Dimmer1 action_on_press', 'Hue Dimmer1 action_off_press'-- change to name of your Hue selector / dimmerswitch
execute = function(dz, device)
deviceToSwitch1 = dz.devices('Woonkamer lamp dressoir')
deviceToSwitch2 = dz.devices('Woonkamer leeslamp 1')
deviceToSwitch3 = dz.devices('Woonkamer staande lamp 1')
deviceToSwitch4 = dz.devices('Woonkamer staande lamp 2')
Dimmer_onpress = dz.devices('Hue Dimmer1 action_on_press')
Dimmer_offpress = dz.devices('Hue Dimmer1 action_off_press')
Dimmer_uppress = dz.devices('Hue Dimmer1 action_up_press')
Dimmer_downpress = dz.devices('Hue Dimmer1 action_down_press')
Dimmer_onpress_hold = dz.devices('Hue Dimmer1 action_on_hold')
dimvalue = deviceToSwitch2.level
Dimmer_lasttime = tonumber(Dimmer_onpress_hold.lastUpdate.secondsAgo)
dz.log('State dimmer press on:' .. Dimmer_onpress.state .. 'secondsago: ' .. Dimmer_onpress_hold.lastUpdate.secondsAgo )
dz.log('State dimmer press off:' .. Dimmer_offpress.state .. 'secondsago: ' .. Dimmer_offpress.lastUpdate.secondsAgo )
if Dimmer_onpress.state == 'Off' and Dimmer_lasttime < 300 then
deviceToSwitch1.switchOn()
deviceToSwitch2.switchOn()
dz.log('Devices 1+2 started')
if Dimmer_onpress_hold.state == 'Off' and Dimmer_onpress_hold.lastUpdate.secondsAgo < 300 then
deviceToSwitch3.switchOn()
deviceToSwitch4.switchOn()
dz.log('Devices 3+4 started ')
if Dimmer_offpress.state == 'Off' and Dimmer_offpress.lastUpdate.secondsAgo < 300 then
deviceToSwitch1.switchOff()
deviceToSwitch2.switchOff()
deviceToSwitch3.switchOff()
deviceToSwitch4.switchOff()
dz.log('All devices switched off')
if Dimmer_uppress == 'Off' then
dimvalue = dimvalue + 10
elseif Dimmer_downpress == 'Off' then
dimvalue = dimvalue - 10
if dimvalue < 5 then
dimvalue = 5
if dimvalue > 100 then
dimvalue = 100
deviceDimmer.level = dimvalue
deviceToSwitch1.dimTo(dimvalue)
deviceToSwitch2.dimTo(dimvalue)
}Is it possible to add the Hue dimmer as a single device with pulldown menu or does anyone know how to get this working?
