bash command  [Solved]
pvklink
Domoticz version: latest b
bash command
Post by pvklink »
I have the follwing script working. Is checks if there are file on a folder and if so , move them to another folder. Accept for file gelukt.txt and file that starts with XXX.
This scripts works and uses a bash script to move the files.
I tried to script the move command from the working bash script in this script (see REMARK 1-3) but that didnt work.
Can you help ?
local timer_overdag = 'every 15 minutes between 06:20 and 23:50 on mon,tue,wed,thu,fri,sat,sun'
    on =    {
            timer = {timer_overdag},
            devices = {'filecopy'},
    execute = function(dz,item,info)
    local sourceDir = '/mnt/mymotion'
    local targetDir = '/mnt/nasdata'
    function exec_os(cmd)
        local f = assert(io.popen(cmd, 'r'))
        s = assert(f:read('*a'))
        f:close()
        return tonumber(s)
    if (item.isDevice and item.name == 'filecopy' and item.state == 'On') or (item.isTimer and item.trigger == timer_overdag) then
        cmd='ls /mnt/myimages -I gelukt.txt | wc -l'
        if exec_os(cmd) > 0 then
            dz.devices('motion files aanwezig').switchOn().checkFirst()
            -- REMARK 1. NOW IN BASHSCRIPT -->     find $sourceDir -type f -not -name "xxx*" -and -not -name "gelukt.txt" -exec mv {} $targetDir \;
            -- REMARK 2. TRY TO EXECUTE ABOVE CMD FROM THIS SCRIPT  --> cmd="find " .. sourceDir .. " -type f -not -name " .. '"xxx*"' .. " -and -not -name " .. '"gelukt.txt"' .. " -exec mv {} " .. targetDir .. " \;"
            -- REMARK 3. DOES NOT WORK, SO USE THE BASH SCRIPT INSTEAD, see below cmd. In this bashscript line 1. is used
            cmd="/opt/domoticz/userdata/filecopy.sh filecopy"
            exec_os(cmd)
            dz.devices('motion files aanwezig').switchOff().checkFirst()
        dz.devices('filecopy').switchOff().afterSec(5)
Jablotron connection, Ikea
willemd
Re: bash command  [Solved]
Post by willemd »
You probably have to use a backslash in front of the double quotes around xxx and gelukt to let dzVents know this double quote should be taken as-is and not interpreted as string start/end.
So use .. '\"xxx*\"' ..
and .. '\"gelukt.txt\"' ..
pvklink
Re: bash command
Post by pvklink »
Ok!, i will try...
And what about the part at the end?, the " \;" ?
willemd
Re: bash command
Post by willemd »
pvklink wrote: Tuesday 07 March 2023 16:16 Ok!, i will try...
I am not sure, maybe you need a double backslash.
If you log the cmd into the log file you probably can see whether the result is correct.
pvklink
Re: bash command
Post by pvklink »
ok, little bit further!
1. this is working line in bash file: find $sourceDir -type f -not -name "xxx*" -and -not -name "gelukt.txt" -exec mv {} $targetDir \;
2. This line in dzvents gives the same line when i print it...
cmd="find " .. sourceDir .. " -type f -not -name " .. '\"xxx*\"' .. " -and -not -name " .. '\"gelukt.txt\"' .. " -exec mv {} " .. targetDir .. " \\;"but it does not
work, and the first line in the bash does...
willemd
Re: bash command
Post by willemd »
I don't see the error right now. I suggest you try to find the error by starting with a simpler cmd and build up gradually to the final desired cmd.
pvklink
Re: bash command
Post by pvklink »
ahh, my mistake, it works! thanks willemd !
the start-end/ characters did the trick and yes an extra / with the last / also..
thanks again!
