Add two kWh meters
MikeyMan
Add two kWh meters
Post by MikeyMan »
Yesterday i installed my second inverter with a couple of panels.
Now i'm trying to add the numbers up to a total. Feel i'm getting close, but not working yet.
return
on =
timer = {
'every minute'
logging =
level = domoticz.LOG_DEBUG,
marker = 'Totaal Zonnepanelen',
execute = function(domoticz, device, item)
-- targetDevice = domoticz.devices(647) -- define as virtual custom sensor
local SolarEdge = domoticz.devices(9).counterToday
local Goodwe = domoticz.devices(632).counterToday
local Total = SolarEdge + Goodwe
domoticz.log('Totaalopbrengst Zonnepanelen counterToday: ' .. Total)
-- targetDevice.updateCustomSensor(Total)
domoticz.devices(647).updateCustomSensor(Total)
Log says:
2023-03-05 11:59:00.186 Status: dzVents: Info: Totaal Zonnepanelen: ------ Start internal script: Script #2:, trigger: "every minute"
2023-03-05 11:59:00.187 Status: dzVents: Debug: Totaal Zonnepanelen: Processing device-adapter for kWh Meter Inverter 1: kWh device adapter
2023-03-05 11:59:00.188 Status: dzVents: Debug: Totaal Zonnepanelen: Processing device-adapter for Goodwe zonnepanelen - Inverter output power (SN: 51000SSX22BW0018): kWh device adapter
2023-03-05 11:59:00.189 Status: dzVents: Info: Totaal Zonnepanelen: Totaalopbrengst Zonnepanelen counterToday: 3.4
2023-03-05 11:59:00.190 Status: dzVents: Debug: Totaal Zonnepanelen: Processing device-adapter for Totaal opbrengst: kWh device adapter
2023-03-05 11:59:00.190 Status: dzVents: Info: Totaal Zonnepanelen: ------ Finished Script #2
2023-03-05 11:59:00.190 Error: dzVents: Error: (3.1.8) Totaal Zonnepanelen: Method updateCustomSensor is not available for device "Totaal opbrengst" (deviceType=General, deviceSubType=kWh). If you believe this is not correct, please report.
also tried a generic counter, but same error:
2023-03-05 12:02:00.285 Error: dzVents: Error: (3.1.8) Totaal Zonnepanelen: Method updateCustomSensor is not available for device "Totaal opbrengst" (deviceType=General, deviceSubType=kWh). If you believe this is not correct, please report.
2023-03-05 12:02:00.286 Error: dzVents: Error: (3.1.8) Totaal Zonnepanelen: Method updateCustomSensor is not available for device "test totaal" (deviceType=RFXMeter, deviceSubType=RFXMeter counter). If you believe this is not correct, please report.
Can you not write values to a kWh custom device :?
roblom
Re: Add two kWh meters
Post by roblom »
I'm no expert but maybe it helps.. I think in the first attempt you try to update the "Totaal" device. In the second attempt you use the "test total" device but this is not a custom device I think
Why do you want too use a custom sensor? Maybe try .updateElectricity?
For more info see
https://www.domoticz.com/wiki/DzVents:_ ... counter.29
MikeyMan
Post by MikeyMan »
roblom wrote: Sunday 05 March 2023 15:46 Why do you use a custom sensor? Maybe try .updateElectricity?
For more info see
Is there another way to add a dummy device?
I'll give that a try thanks!
MikeyMan
Post by MikeyMan »
No luck yet:
2023-03-05 16:40:00.195 Error: dzVents: Error: (3.1.8) Totaal Zonnepanelen: Method updateElectricity is not available for device "test totaal" (deviceType=RFXMeter, deviceSubType=RFXMeter counter). If you believe this is not correct, please report.
2023-03-05 16:41:00.198 Error: dzVents: Error: (3.1.8) Totaal Zonnepanelen: Method updateElectricity is not available for device "test totaal" (deviceType=RFXMeter, deviceSubType=RFXMeter counter). If you believe this is not correct, please report.
willemd
Post by willemd »
Apparently it is not a generic custom sensor but a kwh device? So then you need to use updateElectricity()
willemd
Post by willemd »
MikeyMan wrote: Sunday 05 March 2023 16:41 No luck yet:
and for the rfxmeter counter you need to use updateCounter()
Check the wiki, each type of device has its own update method.
MikeyMan
Post by MikeyMan »
Thanks for the tips, was a bit lost with the device types.
Change to Energy(Usage) type and this script:
return
    on =
        timer = {
			'every minute'
    logging =
        domoticz.devices(648).updateEnergy(Total)
And it seems to be working :D
Although now it shows current wattage instead of totals.
MikeyMan
Post by MikeyMan »
Changed the type around again. Seems to be working for current value. Not so much for the daily totals yet ;)
return
    on =
--        timer = {
--			'every minute'
        devices =   {
            9,
            632
    logging =
        local SolarEdgeToday = domoticz.devices(9).counterToday
        local SolarEdge = domoticz.devices(9).actualWatt
        local GoodweToday = domoticz.devices(632).counterToday
        local Goodwe = domoticz.devices(632).actualWatt
        local TotalToday = SolarEdgeToday + GoodweToday
        domoticz.log('Totaalopbrengst Zonnepanelen actualWatt: ' .. Total)
        domoticz.log('Totaalopbrengst Zonnepanelen counterToday ' .. TotalToday)
--        domoticz.devices(648).updateEnergy(Total)
        domoticz.devices(649).updateElectricity(Total,TotalToday)
Strangely enough the log does show changing values:
2023-03-06 10:36:45.883 Status: dzVents: Info: Handling events for: "Solaredge - kWh Meter Inverter 1", value: "1009.000;26433400.000"
2023-03-06 10:36:45.883 Status: dzVents: Info: Totaal Zonnepanelen: ------ Start internal script: Zonnepanelen: Device: "Solaredge - kWh Meter Inverter 1 (Zonnepanelen)", Index: 9
2023-03-06 10:36:45.884 Status: dzVents: Debug: Totaal Zonnepanelen: Processing device-adapter for Goodwe - Inverter output power: kWh device adapter
2023-03-06 10:36:45.885 Status: dzVents: Info: Totaal Zonnepanelen: Totaalopbrengst Zonnepanelen actualWatt: 1225.0
2023-03-06 10:36:45.885 Status: dzVents: Info: Totaal Zonnepanelen: Totaalopbrengst Zonnepanelen counterToday 2.2
2023-03-06 10:36:45.886 Status: dzVents: Debug: Totaal Zonnepanelen: Processing device-adapter for Totaal opbrengst: kWh device adapter
2023-03-06 10:36:45.886 Status: dzVents: Info: Totaal Zonnepanelen: ------ Finished Zonnepanelen
2023-03-06 10:36:45.887 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
Am i still using the device wrong?
Ah, WhToday makes more sense of the data ;)
willemd
Post by willemd »
For a KWH device you have a choice between "computed" and "from device" when you click on the edit button of the device.
If it is "computed" then the daily value is calculated from the actual values, which is less accurate.
If you have counter values that you want to put on the device then it is best to choose "from device".
roelvdh
Domoticz version: 2024.7
Post by roelvdh »
I am trying to use this. I have added 2 kWh values of 2 devices (solar batteries) into variable Totaal and want to put this total into a virtual sensor, idx 315, type=General, subtype=kWh. I tried your suggestion using:
domoticz.devices(315).computed = Totaal
It runs fine but nothing happens to my virtual device. I just started using dzVents and do not yet understand some of the peculiarities. For instance: How can I find the usable arguments of the fuction domoticz.devices()? You would expect the Domoticz editor to provide such information. sqlite3 domoticz.db didn't help either. Normal road blocks for a starter, I suppose.
FlyingDomotic
Post by FlyingDomotic »
Is Totaal Zonnepanelen a kWh counter?
roelvdh
Post by roelvdh »
No, but my 2 devices are and I am otherwise using the same code. Only, the virtual device containing the added kWh's is not hit.
Edit: The answer is in the docs, as always. I just had not found where to search for this answer. Solved.
