[closed] problem using two different time triggers
BartSr
Domoticz version: V2024.7
Post by BartSr »
Below my code.
		timer = {
			'10 minutes after sunrise',
			'30 minutes after sunset',
	logging = {
		level = domoticz.LOG_INFO,
		marker = 'template',
	execute = function(dz, timer)
	    if (timer == "10 minutes after sunrise") then
	        dz.openURL({
	        url = "http://192.168.2.18/control?cmd=pulse,14,1,500" --luik omhoog
	    if (timer == "30 minutes after sunset") then
	        dz.openURL({
	        url = "http://192.168.2.18/control?cmd=pulse,13,1,500" --luik omlaag
		dz.log('Timer event was triggered by ' .. timer.trigger, dz.LOG_INFO)
This code is intended to open/close window-shutter.
The (somfy) shutter can be controlled using pushbuttons from domoticz.
The pushbuttons do avtivate the shutter using code:
http://192.168.2.18/control?cmd=pulse,14,1,500 for shutter up
and
http://192.168.2.18/control?cmd=pulse,13,1,500 for shutter down
That worked as expected. But as dzVents has better time possibilities for trigger I want to use dzVents.
As seen in the code shutter has to go up 10 min after sunrise and close 30 min after sunset.
But as a matter of facts nothing happens.
What is wrong in my code? Or are my expectations wrong ?
TIA
-Bart
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Esp8266 / 32 espeasy
Zigbee2MQTT
willemd
Re: problem using two different time triggers
Post by willemd »
If you put in several dz.log() statements in your code, you should be able to find out what exactly happens and where the program does not function as expected.
Of course, to avoid waiting a full day for this debugging, you better change the timers while doing this ....
jvdz
Domoticz version: 4.107
Post by jvdz »
Shouldn't the if's be change to timer.trigger?
eg: if (timer.trigger== "10 minutes after sunrise") then
BartSr
Post by BartSr »
Thanks guys, I changed the code with you help into:
		timer = {
			'15 minutes after sunset',
	logging = {
	    if (timer.trigger == "10 minutes after sunrise") then
	        dz.openURL({
	    if (timer.trigger == "15 minutes after sunset") then
	        dz.openURL({
And the changed "timer.trigger" did the job.
I checked by setting the trigger to xx minutes before sunset which made the trigger fire within just a minute.
Problem solved!
Bart
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
