Migating from beta to stable
Posted: Friday 24 February 2023 20:06
by glory50
I've googled and searched this forum and didn't found any positive replies.
Is it possible to remigrate drom beta6 to stable6 or not?
If it is, where could I found some tips for it?
Re: Migating from beta to stable
Posted: Friday 24 February 2023 22:30
I think you have to refrase/clarify your question as this makes absolutely no sense.
Posted: Saturday 25 February 2023 12:26
by glory50
Sorry for the "autocorrection". :shock:
Can DomoticZ 2022.2 (build 14810) be migrated back from beta6 to stable6 'cause I know the DB structures are different?
Posted: Saturday 25 February 2023 13:12
by gizmocuz
When you update to a new version via the GUI, there is a backup made in the backups folder that you can place back.
Anyway, why would you want to go back a version? If something is not working right, tell us, make a issue
Posted: Saturday 25 February 2023 14:23
What do you mean with beta6 and stable6? Do you mean ZigbeeforDomoticz plugin versions? You will have to ask that question to the plugin author pipiche and perhaps read the plugin documentation about Domoticz version and plugin version.
Posted: Saturday 25 February 2023 14:34
by glory50
I didn't mean Zigbee. I meant changing (upgrading) DomoticZ beta6 to stable6 with all the current data in the DB.
OK, I found it: https://domoticz.com/wiki/Going_back_to ... us_version.
Thank you!
Posted: Saturday 25 February 2023 23:37
Good that you found it because I still do not understand stable6 and beta6 in context of Domoticz versions....
https://www.domoticz.com/wiki/Domoticz_ ... _-_Commits
Ps. The only thing you have to do is run ./updaterelease to update or change from beta channel to stable channel in menu setup settings and then check new version in menu setup and update..
