The reverse state of the blinds is not implemented completly or correctly (Solved by workaround) Topic is solved
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
meal
Domoticz version: 2025.1
Re: The reverse state of the blinds is not implemented completly or correctly (Solved by workaround)
Post by meal »
Hi Walter,
I am using RFXCOM RTS Blinds (Somfy)
They are operating perfectly with that change in DomoticzDevices.js
BR
meal
brannou
Domoticz version: 2024.7
Post by brannou »
By now, I am using:
Domoticz version: 2024.7 (build 16348)
Build Hash: 3e66912ba
Compile Date: 2024-11-29 09:19:53
dzVents Version: 3.1.8
Python Version: 3.9.2 (default, Feb 28 2021, 17:03:44) [GCC 10.2.1 20210110]
+ ZigbeeForDomoticz 7.1.007 with a Zigate v1 Zigbee key.
The only issue I have (among dozens of equipment) is this Open/Close behavior with my Legrand/Netatmo AND also my Nodon shutter switches.
Should I apply the workaround or can this issue be solved in another way?
FYI, the "reverse position" doesn't do anything.
It's not very pleasant to have to push Open to close the shutters and push Close to open...
Does anyone have any wise advice?
Thanks,
Bernard
Last edited by brannou on Thursday 12 December 2024 11:03, edited 1 time in total.
brannou
Post by brannou »
Of course I can create a virtual switch doing the opposite but I'd prefer a real one...
brannou
Post by brannou »
Note: I found a solution inside the ZigbeeForDomoticz plugin by adding some parameters to such objects! (inverting shutters)
brannou
Post by brannou »
My temporary (??) solution:
Inside Domoticz
Reverse Open/Close State: not activated
Reverse Position: not activated
Inside ZigbeeForDomoticz
Add { 'netatmoInvertShutter': 1} inside the object parameters via the objects management.
