Hi All,
I am Running a USB RFXtrx433E with
Firmware version = 1028
Firmware Type = Ext
Connected to Domoticz 2023
I brought a Bresser temp/hydro sensor from amazon netherlands(ART No 7000993) and unable to see it in Domoticz or with rfxman, meanwhile my remote blind controls work fine. I have enabled both FineOffset and FineOffset.
I check the latest RFXtrx User Guide, it looks like it is not supported on the RFXtrx433E.
I tried some different firmware but nothing seems to work.
Any advice on which temp/hydo sensors will work with a USB RFXtrx433E and which firmware to use?
Cheers
Tim
Running a RFXtrx433E want a working temp sensor
solarboy
- Domoticz version: 2026.4
Re: Running a RFXtrx433E want a working temp sensor
I bought a bunch of these and they worked well.
https://www.aliexpress.com/item/3288128 ... 18020D6Woz
RedEarth
I have firmware Pro2/1044 and I have Oregon Scientific THGR800 (temp and humidity) and also an older Oregon temp-only sensor (not sure of the model number but Domoticz shows it as "THR128/138, THC138"). Both work nicely.
taw6
I ordered three of the aliexpress ones on the link you mentioned. Can you confirm the firmware version you are running on the RFXtrx433E?
solarboy
Version Pro2 / 1043taw6 wrote: Tuesday 21 February 2023 22:31 I ordered three of the aliexpress ones on the link you mentioned. Can you confirm the firmware version you are running on the RFXtrx433E?
solarboy
They appear as "Alecto WS1700"
taw6
Installed pro2/1043 waiting for the temp sensors to turn up
