Page 1 of 2
Devices dissappeared from Switches, Groups, Temperature, Weather and Other tabs after update
Posted: Monday 13 February 2023 8:50
by pgielen
Computer: RPi 4B
OS: Raspbian Bullseye
Version: 2022.2 (build 15071)
Build Hash: 80379d99a
Compile Date: 2023-02-10 16:52:30
After not having updated Domoticz for some time, I installed the latest beta yesterday. Now, I see no devices anymore on the Domoticz web page under Switches, Groups, Temperature, Weather and Other. The device lists still shows all my devices (which are active), the Dashboard is intact and so is the Floor plan. The scripts are there and work fine.
I tried switching to another dashboard template to see if that solve the problem, but it didn't.
I tried removing some switches in the devices list to inactive and then adding them again by making them active again, but they still do not show up under the Switches tab.
I also tried adding a Camera but the button for that does nothing.
This is weird, maybe a rights issue or a bug in the 10/2 build?
Re: Devices dissappeared from Switches, Groups, Temperature, Weather and Other tabs after update
Posted: Monday 13 February 2023 9:45
Security settings have changed and also the default active menus settings from menu Setup - Settings.
You will have to do that now on the Setup Users menu for the logged in user.
See also wiki https://www.domoticz.com/wiki/Security for more information about security changes in Beta (and coming stable 2023.1)
Edit, and as usual after an update: Clear your browser cache!!! https://www.domoticz.com/wiki/Browser_Cache
Posted: Tuesday 14 February 2023 10:45
by pgielen
(just updated to build 15073)
I can see now that the problem has something to do with the security setup. I have not managed to change this in a way that allows me full access again as a local user with a HTTP connection. The 'About' screen does not display a username after 'Active User: '.
If I use HTTPS I do see my username there and everything works properly again.
I conclude that security has become so strict in the new version that it is no longer even possible to log in locally via HTTP as an admin, is this correct?
Posted: Tuesday 14 February 2023 11:37
by gizmocuz
Did you clear your browser cache? Tried a private window?
Posted: Wednesday 15 February 2023 22:51
by kouinkouin
I had the same issue after update to 2023(dot)1 on my firefox/linux.
On mobile devices, that works.
On private browser window, that works.
On "normal" browser window, I did a Ctrl+F5 and all tabs work.
Posted: Wednesday 22 February 2023 17:45
by anixi
Tried everything cache clearing, restarting, private browsing but still missing switches when using chrome, mobile everything is OK, Also got the "not secure" addition at the address. Als scenes and schedules working fine and devices are visisble in the devices section. ANy idea?
Posted: Thursday 23 February 2023 14:49
by anixi
My devices are back at the switches tab, "repaired" in a strange way (I think). In Chrome, under switches press "learn light/switch", then use domoticz mobile and switch on a missing device; Like a miracle all devices are back again in your chrome domoticz! In conclusion everything upgraded and working fine!
Posted: Thursday 23 February 2023 18:21
by anixi
and they are gone again.......really getting fed up with this. No clue anymore what to do, any suggestion?
Posted: Thursday 23 February 2023 23:44
Do you now see an active user when looking at menu- setup - about? In the screenshot you posted before there is not, indicating you had a browser cache issue.
If you still have no user visible and browser cache is cleared you could try a manual update from terminal with ./updaterelease
It could be that some web scripts files were not correctly.
Posted: Friday 24 February 2023 19:51
by hestia
I've got a similar issue.
Not all devices have disappeared but only the new ones!
ersion: 2023.1 (build 15098)
Build Hash: 867c4e8fa
Compile Date: 2023-02-24 07:56:50
dzVents Version: 3.1.8
Python Version: 3.9.2 (default, Mar 12 2021, 04:06:34) [GCC 10.2.1 20210110]
Just before I was with the release 2023.1 ; I upgraded to the last beta to check if this issue has disappeared! Not :-(
I've added a dummy, present in the list of the device, not in the Switches tab.
Also with the iDetect pluging, but with the iDetect plugins I could see the device if I put it in a plan and use the select list
Screenshot 2023-02-24 194245.jpg (59.11 KiB) Viewed 4126 times
Screenshot 2023-02-24 194014.jpg (40.18 KiB) Viewed 4126 times
Screenshot 2023-02-24 194036.jpg (24.28 KiB) Viewed 4126 times
I've tried with 3 <> browsers (Edge, Chrome, Firefox) and cleared the cache.
I had the devices that were present before the upgrade (but didn't check them all).
The upgrade was in fact a new install on a new server, where I've copied a backup of the DB.
What else to do?
Posted: Tuesday 28 February 2023 17:59
by hestia
this issue does not have a great success ;-) It seems I'm the only ones...
Some more testing:
I've created sensors in each tab: Switches, Temperatures, Weather, Utility
The result:
Screenshot 2023-02-28 175559.jpg (96.24 KiB) Viewed 4100 times
So only the switches does not appear !?!
I don't know if this could help to solve this issue
Posted: Tuesday 28 February 2023 18:06
by hestia
I've created a new user and given him all the devices => same = nothing
I've put the devices in a plan, and select with the plan => same = nothing
Posted: Tuesday 28 February 2023 19:18
by kiddigital
Try to browse the Domoticz UI with the ‘developer tool’ (F12) active. Make sure you are on the ‘network’-tab and select ‘Disable cache’.
Now browse through everything until everything seems ok. Now all webassets should be fully reloaded.
Posted: Tuesday 28 February 2023 19:43
by hestia
I think I could say it is a real bug...
My new switch devices had a bigger order than the existing ones
For instance the AAA5 idx=3029 had his order=3024 (Order, ie the column in the DeviceStatus table)
When I went to the Rom Plan, I could make it go upper in the screen, and I could see it in the device tab with the filter on the Plan :)
Screenshot 2023-02-28 193350.jpg (229.31 KiB) Viewed 4094 times
But not yet with "All"
Then I run this sql update
sqlite3 domoticz.db "UPDATE DeviceStatus SET [Order]=11 WHERE ID=3029"
(not so cool Order is a reserved word!)
And the device jumped at the top of the screen!
Screenshot 2023-02-28 193606.jpg (84.67 KiB) Viewed 4094 times
What is strange is that I could be the first to have more than 3000 'Order'...
Or perhaps I'm the first with this and to add devices (switches) with this version...
Posted: Friday 03 March 2023 9:22
by hestia
kiddigital wrote: Tuesday 28 February 2023 19:18 Try to browse the Domoticz UI with the ‘developer tool’ (F12) active. Make sure you are on the ‘network’-tab and select ‘Disable cache’.
I've done the test right now.
New computer set up yesterday
Cache disabled
Same result (AAAB is not displayed)
Screenshot 2023-03-03 085421.png (321.87 KiB) Viewed 4066 times
Screenshot 2023-03-03 090115.png (92.11 KiB) Viewed 4066 times
Screenshot 2023-03-03 091252.png (204.12 KiB) Viewed 4066 times
After adding the device in a plan and moving up before the "old" ones it appeared ; so for me it's more a data / code subject than a cache subject
Posted: Friday 03 March 2023 9:51
by reinestein
Same problem here, as described in viewtopic.php?p=299574#p299574
reinestein wrote: Monday 20 February 2023 17:18 OK, I nailed it down to: if I create a user with admin rights, I can only see three switches. It doesn't matter if I select any devices in the "set devices" option. If I create a user with "User" rights and exclude one typical switch (a Tuya thermostat switch) then I can see all the switches. Any thoughts?
I still don’t have a clue.
Posted: Friday 03 March 2023 13:25
by gizmocuz
There have been recent changes to ordering or devices in 'room' plans, as there was a bug that caused the order to change not in the specified room but in the 'all' room (so to speak)
I will try to replicate and debug this issue
Anyway, please not that the order in a room is a different order than in the 'All' room (no room)
Posted: Friday 03 March 2023 14:05
by gizmocuz
I am unable to replicate your issue
I added 3 dummy switches and they showed up on the switches page
Maybe sure you have only 1 admin user and that you configured it so it has all devices
A admin is a admin
Posted: Friday 03 March 2023 14:45
by hestia
Previously it was not necessary to give the devices to admin... and to have only one admin...
Anyway I've just configured the admin so it has all devices
And I had several admin, I've deleted all except one.
No change, same issue
With the plan selection on All or Test
Screenshot 2023-03-03 142246.png (164.2 KiB) Viewed 4030 times
I'd say that it's not only the new devices created with the new version but also the previous ones (but, I had installed some betas previously...)
Before the Order 1123 (included) they appeared, after 1123 I could not seem them! (I did this test on samples around the breaking line)
Screenshot 2023-03-03 143323.png (69.9 KiB) Viewed 4030 times
I could send you my DB (16MB) if it can help...
Posted: Friday 03 March 2023 15:08
by hestia
what is strange is that it works on my prod env with also high Order values !!!
Screenshot 2023-03-03 150057.png (63.6 KiB) Viewed 4025 times
Screenshot 2023-03-03 150219.png (67.94 KiB) Viewed 4025 times
prod
About Domoticz
Version: 2022.2 (build 15022)
Build Hash: af4316cb7
Compile Date: 2023-02-03 16:33:14
Python Version: 3.7.3 (default, Jan 22 2021, 20:04:44) [GCC 8.3.0]
test
About Domoticz
Version: 2023.1 (build 15098)
