Import Electric data to domoticz electric(instant+counter)
Posted: Sunday 12 February 2023 9:27
by naeblizz
Hi . I am trying to import sensor data, electricity reading from node red to domoticz. Right now I have 2 dummy sensors general purpose which recives mqtt data from node red to display instant energy consumption and energy counter . This works fine, my problem now is that I am trying to merge those 2 values to 1 dummy sensor "electric(instant+counter)" . I can't seem to get the mqtt syntax right because I get no value on the new sensor when trying to send data. This is what I send to domoticz/in from node red with my general purpose sensor :
{ "idx" : 5041, "nvalue" : {{payload}}, "svalue" : "{{payload}}" }
Im trying to send the same to the electric dummy sensor but I get no value on that one. Anyone knew what I am doing wrong ?
//Mikael
Re: Import Electric data to domoticz electric(instant+counter)
Posted: Sunday 12 February 2023 9:50
by naeblizz
I got it working . tnx anyway
Posted: Wednesday 01 March 2023 18:23
by JustDude
I just had the same question,,, looking for the right value to store the value from Node-red.
I tried svalue, usage, consumed. Nothing works as I would expect.
Is there a datamodel or approach on where to find the correct way?
By the way: Would be nice if you know the solution to let (me) us and other readers know
Posted: Wednesday 01 March 2023 18:35
by waltervl
There is a node-red subforum here :
https://domoticz.com/forum/viewforum.php?f=81
The mqtt message should have the right mqtt format. Are you already able to update the sensor by sending an mqtt message manual?
See wiki
https://www.domoticz.com/wiki/MQTT#MQTT_to_Domoticz
Edit: Electric
The electric sensor will show the current usage of electricity in Watt and the cumulative usage in kWh. You can add digits after the decimal if needed.
{"command":"udevice", "idx":1234, "svalue":"us;cu"}
where us is usage in Watt and cu is cumulative usage in Wh (even though it is displayed in kWh)
Posted: Thursday 02 March 2023 21:42
by JustDude
Thanks that helped. Found the Node-red subforum also.
Posted: Thursday 17 August 2023 18:37
by averter
I am trying to do something similar. I've created an instantaneous electric virtual device and want to replace it with an electric (instant + counter) type, but the "instant + counter" device is not listed in the new device drop down menu from the "instantaneous" device. Is there any simple workaround? Thank you in advance.
Averter
Posted: Thursday 17 August 2023 18:53
by FireWizard
Hello @averter,
I have no idea where and what you have created, being "an instantaneous electric virtual device".
Can you give more details?
I think, that you should create in "Hardware" a "Dummy (Does nothing, use for virtual switches only)".
After that you click "Create Virtual Sensors" and select "Electric (Instant + Counter)".
I think that is what you need.
Posted: Thursday 17 August 2023 20:25
by averter
Hello @FireWizard,
Thanks and apologies for not being clear. I have one dummy hardware device and have created a virtual sensor of the type "usage (electric)": this is what I mean by instantaneous electric virtual device. It works fine, but it doesn't include an energy counter in kWh, only the kW instantaneous reading, hence why I would like to transfer its log to another virtual sensor of the type "electric (instant + counter)".
Posted: Thursday 17 August 2023 22:12
by willemd
Is the kWh device set to "computed" or "from device" (using the edit button) ?
If set to computed, then domoticz will calculate the energy from the instantaneous values.
Posted: Thursday 17 August 2023 22:19
by FireWizard
Hi @averter,
Sorry, that I did not understand your own naming of a virtual "Usage" sensor.
A virtual sensor of the type "Usage" will show you the actual usage in Watt and not the Consumed or Produced Energy.
Therefore you need a sensor of the type: "Electric (Instant + Counter)". but you have to upload also the cumulative usage in Wh.
But, as far as I know, to replace an old sensor for a new one, both have to be of the same type. However this is not the case, so I cannot guarantee any success.
Posted: Thursday 17 August 2023 23:13
by averter
willemd wrote: Thursday 17 August 2023 22:12
Thanks for letting me know about that option, but my question sort of remains the same. How can I transfer all the instantaneous values from the "usage (electric)" device to the new "electric (instant + counter)" device? Thanks
Posted: Thursday 17 August 2023 23:16
by averter
FireWizard wrote: Thursday 17 August 2023 22:19
Hi @averter,
According to the previous reply from willemd it should be possible to calculate the cumulative usages by setting the "computed" instead of "from device" option in the Electric (Instant + Counter)" device, which would sort of make these two sensors equivalent?
Posted: Thursday 17 August 2023 23:25
by FireWizard
@averter,
You can try, but I never did that.
What @willemd said is correct, but he did not say, that you can replace two different type of sensors with each other.
Posted: Friday 18 August 2023 22:11
by willemd
Indeed, I don't know about transferring data between sensors. I would look into the database see which tables are used for the various sensors, how the structure is and then use sqlite to do a transfer (after first making a backup). Not an easy answer. Maybe there are other options.
Posted: Friday 18 August 2023 22:35
by averter
willemd wrote: Friday 18 August 2023 22:11
Yes, sqlite is probably my best bet. I'll give it a go after my next backup. Thanks both!
