Goodwe solar inverter via Web API
Posted: Friday 10 February 2023 6:28
by Jan Jansen
Can this native hardware type still be used? I miss a howto, but maybe I didn't search properly. I can't get it working.
Thanks in advance
Re: Goodwe solar inverter via Web API
Posted: Friday 10 February 2023 10:00
Currently it does not work, that is why python plugins are being created
https://github.com/domoticz/domoticz/issues/5393
Posted: Friday 10 February 2023 12:51
by Jan Jansen
@waltervl
Thanks for your reply. Too bad the native hardware doesn't work anymore.
Regards!
Posted: Friday 10 February 2023 16:17
by willemd
If this is a traditional central inverter for solar panels and you can't get data directly from the inverter, you could as an alternative still install a kWh meter on the AC power line and measure the total solar panel output in that way. That is what I do. I use the homewizard wifi kwh meter. (Originally I had the plugwise connector but that stopped working)
Posted: Saturday 11 February 2023 1:27
The python plugins for the goodwe inverters are functional so you can use one of those (one for web and one for modbus) see https://www.domoticz.com/wiki/Plugins
Posted: Saturday 11 February 2023 8:53
by gizmocuz
Or maybe someone can update the c++ code?
