fibaro universal sensor problem
Posted: Tuesday 07 February 2023 21:59
by tjabas
hi!
i have a fibaro universal sensor that i have 2 pcs of ds18b20 connected, these have been working good for a couple of years but today they have stopped to update the temperateur, i have to update the node information under open-zwave and settings, then it updates the the temp, but just only once, i have rebooted the rpi and i have rebooted the fibaro sensor, but it wont help.
do you have any suggestions?
thanks in advance
Re: fibaro universal sensor problem
Posted: Wednesday 08 February 2023 8:25
by gizmocuz
Are you using ZWaveJS-UI? If not, there have been no development on OpenZWave neither is there any development in Domoticz related to OZW.
Maybe it is a problem with the mesh network, or a faulty sensor. But I would try with ZWaveJS-UI
Posted: Wednesday 08 February 2023 9:37
by lost
tjabas wrote: Tuesday 07 February 2023 21:59
i have to update the node information under open-zwave and settings, then it updates the the temp, but just only once...
I have similar issue that appeared after years of use on a Qubino Smart-Meter: If my house main power is lost (fortunately not so often), looks it now does not keeps internal parameters anymore (maybe some device flash memory ageing issue, so only current parameter set in RAM can be kept... until a power-cut). So everything goes back to defaults and I don't see updates with configured thresholds+times. Relay commands settings are also lost so cannot be switched anymore (+ no more load-shedding as well).
Refresh node-info and reconfiguring => Everything back as expected.
IMO, this may be device issue.
Posted: Wednesday 08 February 2023 17:53
by tjabas
thanks for your answers, suddenly it stated to update again, but it seems like it updates sporadically, i think i will have to exclude and include it again.
