node red x domoticz x nora
Posted: Saturday 04 February 2023 18:15
by henrybcn
Hi All,
I have been using node red x nora x domoticz for several months now....
but something is weird now.....
I have a flow in NODE RED as below. I can turn it on by voice (google home) and it switches on domoticz and nora on the web, but not physically. Never saw this behaviour before.
If I turn on/off in domoticz/nora it works in both ways (on the web and physically)
Any clue why this happens and how I can sort it out?
Tks much!
Henry
Re: node red x domoticz x nora
Posted: Saturday 04 February 2023 18:26
by FireWizard
Hello @henrybcn,
You said the following:
How do you switch your pool device?
This looks as a MQTT (not) loop issue.
Posted: Sunday 05 February 2023 11:41
by henrybcn
hi FireWizard,
I can turn on/off with domoticz or NORA and it works perfectly! But when I use google mini (voice), something gets stuck as the switch in domoticz turn on, but the light does not. Any clue how I can troubleshoot?
Tks!
Posted: Sunday 05 February 2023 12:32
by FireWizard
Hello @henrybcn,
I asked:
This looks like a MQTT loop issue.
If you operate the switch in Domoticz, what is supposed to happen? Do you send a MQTT command to some device, that should switch physically your pool device? If it is a MQTT command, you should set this setting "Prevent Loop" to "False".
Have a look at your settings:
Screenshot_MQTT loop.png (29.8 KiB) Viewed 2716 times
Posted: Monday 06 February 2023 9:23
by henrybcn
fantastic! Now everything works. Would never figure this out by myself! Tks @FireWizard!!!
