Installed Domoticz 2022.2 fresh at Debian 11 NUC. No python loaded by Domoticz. Python is installed version 3.9, see picture. Any suggestions?
About Domoticz
Version: 2022.2
Build Hash: eea9db734
Compile Date: 2022-11-05 13:05:35
dzVents Version: 3.1.8
Python Version: None
Debian 11 install Domoticz 2022.2 no python loaded
tonbor
- Schermafdruk_2023-02-01_11-25-04.png (160.48 KiB) Viewed 1559 times
- Sjonnie2017
- Domoticz version: Latest ß
Re: Debian 11 install Domoticz 2022.2 no python loaded
You need more than just the libs. Have you installed PYthon3?
YouLess Energy meter
- Domoticz version: 2026.3
Check Wiki page https://www.domoticz.com/wiki/Using_Python_plugins
tonbor
rob@NUC5-Rob:~$ python3 -VSjonnie2017 wrote: Wednesday 01 February 2023 11:49 You need more than just the libs. Have you installed PYthon3?
Python 3.9.2
rob@NUC5-Rob:~$ dpkg --get-selections | grep libpython
libpython3-stdlib:amd64 install
libpython3.9:amd64 install
libpython3.9-minimal:amd64 install
libpython3.9-stdlib:amd64 install
rob@NUC5-Rob:~$
- Sjonnie2017
The wiki says:
Have you tried that?If you still do not see the python version in Domoticz menu Setup - About Domoticz please install python3-dev:
sudo apt install python3-dev
Restart Domoticz.
tonbor
Yes, still no python in the about of Domoticz, but ..... python is present and working.
While starting Domoticz it will normally log some info on Python. Are there some clues to see?
sieth
- Domoticz version: 2020.2
I had to do this for it to work:
wget http://nz2.archive.ubuntu.com/ubuntu/po ... _amd64.deb
sudo dpkg -i *.deb
Maybe, it will work for you as well.
sudo dpkg -i *.deb
