update changed behaviour of P1 dial
Posted: Wednesday 01 February 2023 11:17
by willemd
I updated to latest Dashticz version today and as result my P1 dial that showed daily total before now showed actual value and was going in reverse.
I solved it by adding
values: [
value: 'CounterToday',
isNeedle: true,
scale: -1,
to the dial block definition.
But why did it change behaviour? Has the default behaviour changed?
Re: update changed behaviour of P1 dial
Posted: Wednesday 01 February 2023 11:36
by willemd
- Screenshot-2023-02-01-112636.jpg (19.97 KiB) Viewed 178 times
- Screenshot-2023-02-01-113425.jpg (19.66 KiB) Viewed 178 times
The update also added back the incorrect unit display. It should be kWh.
So I had to adapt the block definition also to get that correct again. It now reads:
blocks['P1_today'] = {
idx: 1,
title:'Grid today',
type: 'dial',
values: [
isNeedle: true,
scale: -1,
unit: 'kWh',
showunit: true
min: -10,
max: 10,
decimals: 3,
showring: true,
showunit: false,
shownumber: true,
width: 4
Posted: Wednesday 01 February 2023 22:44
by Lokonli
willemd wrote: Wednesday 01 February 2023 11:17
values: [
isNeedle: true,
scale: -1,
There was some change in the code to make behavior consistent with other power devices, some functionality has been added.
The unit should be ok, I'll check.
Good that you found a way already to adapt it to your needs.
