How to add AXPERT MAX 8KW WIFI/USB/RS232 in domoticz ?
PIFOUBMW
Post by PIFOUBMW »
Hello from France,
I just bought and installed an AXPERT MAX 48V 8KW HYBRID INVERTER with built-in WIFI module (but defective, the seller still searching the solution, but I think the display with integrated mini-wifi card must be replaced under warranty :| )
The defective built-in wifi should work on the cloud with android APP (SmartESS, WatchPower or SolarPower ==> very similars apps)
Actually the microUSB port is working on my windows laptop with watchpower v1 14 free software.
Is is possible to have this AXPERT inverter in domoticz ? Does it exist a pluggin with the WIFI or USB connexion ?
Thanks :P
AXPERT MAX 8KW INVERTER.jpg (116.62 KiB) Viewed 1644 times
Re: How to add AXPERT MAX 8KW WIFI/USB/RS232 in domoticz ?
Axpert seems to be similar as Voltronic so perhaps the application below can communicate with Domoticz MQTT Autodiscover Gateway. https://www.domoticz.com/wiki/MQTT#Add_ ... Gateway.22
https://github.com/ned-kelly/docker-vol ... eassistant
PIFOUBMW
Post by PIFOUBMW »
Thanks :P
It seems working for my AXPERT because I found : "Voltronic/Axpert/MPPSolar based inverter that you want to monitor"
But it works with home assistant and not domoticz then I don't know how to do it :cry:
It uses mqtt for Homeassistant. Domoticz MQTT can also use MQTT homeassistant (Autodiscover). So there is a good possibility that it works. See the Domoticz wiki I linked to.
